10/3/22, 1:35 AM
Low Voltage, Filament High Current, Chassis Mount - 125 VA to 440 VA (165 Series) - Hammond Mfg.
Quality Products. Service Excellence.
VA 165 Series
115 V Primary
Features
115 VAC - 60 Hz. single primary
All secondaries are center tapped (C.T.)
Open style, 4 hole frame chassis mount.
Minimum 6" long leads or copper tabs with holes.
Dual bobbin design - no electrostatic shield required.
Class B insulation (130 degrees, C).
Hi-Pot test of 2,000V RMS.
UL listed (# E207860) Type 3AH
CSA certified (# LR209651).
Secondary (R.M.S.)
Dimensions
Part No.
VA
VAC
Amps
A
B
C
D
E
F
Mounting Slot
165Z3
150
3.0 C.T.
50
3.75
3.13
3.13
3.13
2.75
3.50
0.22
x
0.56
165X5
150
5.0 C.T.
30
3.75
2.63
3.13
3.13
2.50
3.25
0.22
x
0.56
165V7
157.5
7.5 C.T.
21
3.75
2.63
3.13
3.13
2.50
3.25
0.22
x
0.56
165V10
200
10.0 C.T.
3.13
3.13
3.13
2.75
3.50
0.22
x
0.56
165U11
165
11.0 C.T.
15
3.75
2.63
3.13
3.13
2.50
3.25
0.22
x
0.56
165S12
126
12.6 C.T.
10
3.00
3.25
2.56
2.50
3.25
4.00
0.22
x
0.56
https://www.hammfg.com/electronics/transformers/power/165
1/2
10/3/22, 1:35 AM
Secondary (R.M.S.)
Dimensions
Part No.
VA
VAC
Amps
A
B
C
D
E
F
165V12
252
12.6 C.T.
3.63
3.13
3.13
3.25
4.00
0.22
Mounting Slot
x
0.56
165S18
180
18.0 C.T.
10
3.75
3.13
3.13
3.13
2.75
3.50
0.22
x
0.56
165U18
270
18.0 C.T.
15
4.50
3.88
3.75
3.75
2.75
3.50
0.28
x
0.56
165V18
360
18.0 C.T.
4.38
3.75
3.75
3.25
4.00
0.28
x
0.56
165T22
264
22.0 C.T.
12
4.50
3.88
3.75
3.75
2.75
3.50
0.28
x
0.56
165V22
440
22.0 C.T.
4.38
3.75
3.75
3.75
4.50
0.28
x
0.56
165P25
125
25.0 C.T.
5
3.00
3.25
2.56
2.50
3.25
4.00
0.22
x
0.56
165S25
250
25.0 C.T.
10
3.75
3.63
3.13
3.13
3.25
4.00
0.22
x
0.56
165P30
150
30.0 C.T.
5
3.00
3.25
2.56
2.50
3.25
4.00
0.22
x
0.56
165S30
300
30.0 C.T.
10
4.50
3.88
3.75
3.75
2.75
3.50
0.28
x
0.56
165P60
300
60.0 C.T.
5
4.50
3.88
3.75
3.75
2.75
3.50
0.28
x
0.56
165N80
320
80.0 C.T.
4
4.50
4.38
3.75
3.75
3.25
4.00
0.28
x
0.56
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“165T22”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+946.978891+122.52782
