166L12
166L12
    HAMMONDMANUFACTURING
    XFRMRLAMINATED31.5VACHASMNT
166L12 数据手册
www.hammondmfg.com 166L12 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 3.25 / 82.6 B 2 / 50.8 C 2 / 50.8 Schematic Blk Hole to Hole Mounting Dims D Grn 2.81 / 71.4 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 31.5 Primary 115V 60 Hz. Secondary VAC 12.6 C.T. Secondary Amps 2.5 Primary / Grn/ Yel Blk Grn Secondary E
166L12 价格&库存
很抱歉,暂时无法提供与“166L12”相匹配的价格&库存,您可以联系我们找货
166L12
  • 1+208.000441+26.91041
  • 10+185.4190310+23.98890
  • 25+177.0877025+22.91102
  • 50+171.0295650+22.12724
  • 100+165.17453100+21.36974
  • 250+157.73337250+20.40703
  • 500+152.32497500+19.70730
库存:41
