161E24
161E24
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 1.2VA THRU HOLE
161E24 数据手册
10/3/22, 1:35 AM Low Voltage PC Board Mount, 0.5 VA to 24 VA (160-161 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage PC Board Mount, 0.5 VA to 24 VA 160-161 Series Low Voltage, P.C. Board Mount Vertical - 115 & 115/230 V Primary Features 20 output voltages to choose from (5 - 120VAC R.M.S.) Six VA size models available from - .5 to 24 VA Vertical mount, split bobbin design. 1.2, 4.4, 10, 24 VA models are non-concentric wound. 0.5 and 1 VA are both concentric wound. Low primary to secondary coupling - no electrostatic shield required. Choice of economical single primary 115V - 60 Hz only (161 series) or the universal dual primary 115/230V - 50/60 Hz (160 series). High insulation - Hipot of 2,000V RMS. Class B insulation - 130 degrees C. CSA certified (File # LR3902) and UL recognized (File #E207860).     https://www.hammfg.com/electronics/transformers/power/160-161 1/4 10/3/22, 1:35 AM Low Voltage PC Board Mount, 0.5 VA to 24 VA (160-161 Series) - Hammond Mfg. Part No Part No Single Primary Dual Primary Size 115V 115/230V VA https://www.hammfg.com/electronics/transformers/power/160-161 Secondary (RMS) Series Parallel 2/4 10/3/22, 1:35 AM Low Voltage PC Board Mount, 0.5 VA to 24 VA (160-161 Series) - Hammond Mfg. Part No Part No Single Primary Dual Primary Size 115V 115/230V VA Series Parallel 161C10 - Secondary (RMS) 0.5 10V C.T. @ 50ma 5V @ 100ma 161D10 160D10 1 10V C.T. @ 90ma 5V @ 180ma 161FA10 160F10 1.2 10V C.T. @ 120ma 5V @ 240ma 161GA10 160G10 4.4 10V C.T. @ 440ma 5V @ 880ma 161J10 160J10 10 10V C.T. @ 1A 5V @ 2A 161H10 161C12 160H10 24 10V C.T. @ 2.4A 5V @ 4.8A 0.5 12.6V C.T. @ 40ma 6.3V @ 80ma 160D12 1 12.6V C.T. @ 70ma 6.3V @ 140ma - 161D12 161FA12 160F12 1.2 12.6V C.T. @ 100ma 6.3V @ 200ma 161GA12 160G12 4.4 12.6V C.T. @ 350ma 6.3V @ 700ma 161K12 160K12 10 12.6V C.T. @ 800ma 6.3V @ 1.6A 161H12 160H12 24 12.6V C.T. @ 2A 6.3V @ 4A 161C16 0.5 16V C.T. @ 31.3ma 8V @ 62.5ma 161D16 160D16 1 16V C.T. @ 55ma 8V @ 110ma 161EA16 160E16 1.2 16V C.T. @ 75ma 8V @ 150ma 161FA16 160F16 4.4 16V C.T. @ 260ma 8V @ 520ma 161G16 160G16 10 16V C.T. @ 640ma 8V @ 1.28A 161H16 160H16 24 16V C.T. @ 1.5A 8V @ 3A 161D20 160D20 1 20V C.T. @ 45ma 10V @ 90ma 161EA20 160E20 1.2 20V C.T. @ 60ma 10V @ 120ma 161FA20 160F20 4.4 20V C.T. @ 220ma 10V @ 440ma 161G20 160G20 10 20V C.T. @ 500ma 10V @ 1A 161H20 160H20 24 20V C.T. @ 1.2A 10V @ 2.4A 161D24 160D24 1 24V C.T. @ 35ma 12V @ 70ma 161E24 160E24 1.2 24V C.T. @ 50ma 12V @ 100ma 161F24 160F24 4.4 24V C.T. @ 180ma 12V @ 360ma 161G24 160G24 10 24V C.T. @ 450ma 12V @ 900ma 161H24 160H24 24 24V C.T. @ 1A 12V @ 2A 161D28 160D28 1 28V C.T. @ 30ma 14V @ 60ma 161E28 160E28 1.2 28V C.T. @ 40ma 14V @ 80ma 161F28 160F28 4.4 28V C.T. @ 160ma 14V @ 320ma 161G28 160G28 10 28V C.T. @ 360ma 14V @ 720ma 161H28 160H28 24 28V C.T. @ 800ma 14V @ 1.6A 161D34 160D34 1 34V C.T. @ 25ma 17V @ 50ma 161E34 160E34 1.2 34V C.T. @ 35ma 17V @ 70ma 161F34 160F34 4.4 34V C.T. @ 125ma 17V @ 250ma 161G34 160G34 10 34V C.T. @ 300ma 17V @ 600ma 161H34 160H34 24 34V C.T. @ 700ma 17V @ 1.4A 161D40 160D40 1 40V C.T. @ 20ma 20V @ 40ma 161E40 160E40 1.2 40V C.T. @ 30ma 20V @ 60ma 161F40 160F40 4.4 40V C.T. @ 110ma 20V @ 220ma 161G40 160G40 10 40V C.T. @ 250ma 20V @ 500ma 161H40 160H40 24 40V C.T. @ 600ma 20V @ 1.2A 161D56 160D56 1 56V C.T. @ 15ma 28V @ 30ma 161E56 160E56 1.2 56V C.T. @ 20ma 28V @ 40ma 161F56 160F56 4.4 56V C.T. @ 80ma 28V @ 160ma 161G56 160G56 10 56V C.T. @ 180ma 28V @ 360ma 161H56 160H56 24 56V C.T. @ 420ma 28V @ 840ma 161D120 160D120 1 120V C.T. @ 8ma 60V @ 16ma 161E120 160E120 1.2 120V C.T. @ 10ma 60V @ 20ma 161F120 160F120 4.4 120V C.T. @ 35ma 60V @ 70ma 161G120 160G120 10 120V C.T. @ 85ma 60V @ 170ma 161H120 160H120 24 120V C.T. @ 200ma 60V @ 400ma https://www.hammfg.com/electronics/transformers/power/160-161 3/4 10/3/22, 1:35 AM Low Voltage PC Board Mount, 0.5 VA to 24 VA (160-161 Series) - Hammond Mfg. Mechanical & Schematic Data (160 Series): Size (VA) Overall Dimensions A B C D Thickness D Width E F Thickness F Width G H J 1 1.00 1.38 0.83 0.02 0.04 1.20 - - 0.20 N/A N/A 1.2 1.38 1.19 1.22 0.02 0.04 1.00 - - 0.20 N/A N/A 4.4 1.69 1.25 1.45 0.02 0.04 1.10 0.03 0.12 0.25 1.67 0.46 10 1.94 1.44 1.69 0.02 0.04 1.30 0.03 0.19 0.25 1.89 0.57 24 1.63 2.25 1.38 0.02 0.04 2.10 - - 0.25 N/A N/A Mechanical & Schematic Data (161 Series): Size (VA) Overall Dimensions A B C D Thickness D Width E F Thickness F Width G H J 0.5 1.00 0.94 0.84 0.025 0.03 0.78 - - 0.25 - - 1 1.00 1.38 0.83 0.02 0.04 1.20 - - 0.25 - - 1.2 1.38 1.19 1.22 0.02 0.04 1.00 - - 0.31 - - 4.4 1.69 1.25 1.45 0.02 0.04 1.10 0.03 0.12 0.40 1.67 0.44 10 1.94 1.44 1.69 0.02 0.04 1.30 0.03 0.19 0.40 1.89 0.55 24 1.63 2.25 1.38 0.02 0.04 2.10 - - 0.40 - - Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/160-161 4/4
161E24
1. 物料型号:文档列出了多种型号的变压器,包括单相115V和双相115/230V输入的变压器,容量从0.5 VA到24 VA不等。
2. 器件简介:这些变压器设计用于低压、PCB板安装,具有垂直安装、分裂线圈设计,无需静电屏蔽,具有高绝缘性能,并通过CSA和UL认证。
3. 引脚分配:文档提供了详细的引脚分配图,包括主次级连接方式,如PIN SIZE和TAB SIZE。
4. 参数特性:列出了多种输出电压选项,以及在不同容量下的电流传输特性(C.T.表示电流传输)。
5. 功能详解:文档强调了变压器的低原副边耦合特性,无需静电屏蔽,以及高绝缘性能。
6. 应用信息:虽然文档没有直接提供应用案例,但从其特性来看,这些变压器适用于需要低压电源的各种电子设备。
7. 封装信息:提供了变压器的尺寸和机械数据,包括整体尺寸、厚度、宽度等。
161E24 价格&库存
很抱歉,暂时无法提供与“161E24”相匹配的价格&库存,您可以联系我们找货
161E24
    • 1+79.162611+9.45943
    • 10+63.3664310+7.57189
    库存:35
