164D28
164D28
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 1.1VA THRU HOLE
164D28 数据手册
10/3/22, 1:23 AM Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA (162-164 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA 162-164 Series Features 20 output voltages to choose from (5 - 120VAC R.M.S.) Six VA size models available from - 1.1 to 36VA Both series operate on 50/60 Hz current Low profile, split bobbin design. Dual winding secondaries, non-concentrically wound Units are designed so that all windings must be used Low primary to secondary coupling - no electrostatic shield required. Choice of economical single primary 115V (164 series) or universal dual primary 115/230V (162 series) - either model 50/60 Hz operation. High insulation - Hipot of 2,500V RMS. Class B insulation - 130 degrees C. No mounting hardware required on 1.1 and 2.4 VA sizes, two hole mounting on 6, 12 and 20VA sizes, four hole mounting on 36VA size (mounting screws not provided). P.C. board     mount with industry standard pin spacing. c UL us recognized https://www.hammfg.com/electronics/transformers/power/162-164 1/4 10/3/22, 1:23 AM Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA (162-164 Series) - Hammond Mfg. Part No Part No Single Primary Dual Primary Size 115V 115/230V VA Series Parallel 164D10 162D10 1.1 10V C.T. @ .11A 5V @ .22A 164E10 162E10 2.4 10V C.T. @ .25A 5V @ .5A 164F10 162F10 6 10V C.T. @ .6A 5V @ 1.2A 164G10 162G10 12 10V C.T. @ 1.2A 5V @ 2.4A 164H10 162H10 20 10V C.T. @ 2A 5V @ 4.0A Secondary (RMS) 164J10 162J10 36 10V C.T. @ 3.6A 5V @ 7.2A 164D12 162D12 1.1 12.6V C.T. @ .09A 6.3V @ .18A 164E12 162E12 2.4 12.6V C.T. @ .2A 6.3V @ .4A 164F12 162F12 6 12.6V C.T. @ .5A 6.3V @ 1.0A 164G12 162G12 12 12.6V C.T. @ 1.0A 6.3V @ 2.0A 164H12 162H12 20 12.6V C.T. @ 1.6A 6.3V @ 3.2A 164J12 162J12 36 12.6V C.T. @ 2.85A 6.3V @ 5.7A 164D16 162D16 1.1 16V C.T. @ .07A 8V @ .14A 164E16 162E16 2.4 16V C.T. @ .15A 8V @ .3A 164F16 162F16 6 16V C.T. @ .4A 8V @ .8A 164G16 162G16 12 16V C.T. @ .8A 8V @ 1.6A 164H16 162H16 20 16V C.T. @ 1.25A 8V @ 2.5A 164J16 162J16 36 16V C.T. @ 2.25A 8V @ 4.5A 164D20 162D20 1.1 20V C.T. @ .055A 10V @ .11A 164E20 162E20 2.4 20V C.T. @ .12A 10V @ .24A 164F20 162F20 6 20V C.T. @ .3A 10V @ .6A 164G20 162G20 12 20V C.T. @ .6A 10V @ 1.2A 164H20 162H20 20 20V C.T. @ 1A 10V @ 2.0A 164J20 162J20 36 20V C.T. @ 1.8A 10V @ 3.6A 164D24 162D24 1.1 24V C.T. @ .045A 12V @ .09A 164E24 162E24 2.4 24V C.T. @ .1A 12V @ .2A https://www.hammfg.com/electronics/transformers/power/162-164 2/4 10/3/22, 1:23 AM Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA (162-164 Series) - Hammond Mfg. Part No Part No Single Primary Dual Primary Size 115V 115/230V VA Series Secondary (RMS) Parallel 164F24 162F24 6 24V C.T. @ .25A 12V @ .5A 164G24 162G24 12 24V C.T. @ .5A 12V @ 1.0A 164H24 162H24 20 24V C.T. @ .8A 12V @ 1.6A 164J24 162J24 36 24V C.T. @ 1.5A 12V @ 3.0A 164D28 162D28 1.1 28V C.T. @ .04A 14V @ .08A 164E28 162E28 2.4 28V C.T. @ .085A 14V @ .17A 164F28 162F28 6 28V C.T. @ .2A 14V @ .4A 164G28 162G28 12 28V C.T. @ .42A 14V @ .84A 164H28 162H28 20 28V C.T. @ .7A 14V @ 1.4A 164J28 162J28 36 28V C.T. @ 1.3A 14V @ 2.6A 164D36 162D36 1.1 36V C.T. @ .03A 18V @ .06A 164E36 162E36 2.4 36V C.T. @ .065A 18V @ .13A 164F36 162F36 6 36V C.T. @ .17A 18V @ .34A 164G36 162G36 12 36V C.T. @ .35A 18V @ . 7A 164H36 162H36 20 36V C.T. @ .55A 18V @ 1.1A 164J36 162J36 36 36V C.T. @ 1A 18V @ 2.0A 164D48 162D48 1.1 48V C.T. @ .023A 24V @ .046A 164E48 162E48 2.4 48V C.T. @ .05A 24V @ .1A 164F48 162F48 6 48V C.T. @ .125A 24V @ .25A 164G48 162G48 12 48V C.T. @ .25A 24V @ .5A 164H48 162H48 20 48V C.T. @ .4A 24V @ .8A 164J48 162J48 36 48V C.T. @ .75A 24V @ 1.5A 164D56 162D56 1.1 56V C.T. @ .02A 28V @ .04A 164E56 162E56 2.4 56V C.T. @ .045A 28V @ .09A 164F56 162F56 6 56V C.T. @ .11A 28V @ .22A 164G56 162G56 12 56V C.T. @ .22A 28V @ .44A 164H56 162H56 20 56V C.T. @ .35A 28V @ .7A 164J56 162J56 36 56V C.T. @ .65A 28V @ 1.3A 164D120 162D120 1.1 120V C.T. @ .01A 60V @ .02A 164E120 162E120 2.4 120V C.T. @ .02A 60V @ .04A 60V @ .1A 164F120 162F120 6 120V C.T. @ .05A 164G120 162G120 12 120V C.T. @ .1A 60V @ .2A 164H120 162H120 20 120V C.T. @ .16A 60V @ .32A 164J120 162J120 36 120V C.T. @ .3A 60V @ .6A Mechanical & Schematic Data (VA) Part Number Size Letter L W H A Dimensions B C M N P Mounting Screw Weight lbs. 1.1 D 1.38 1.13 15/16 0.25 0.25 1.2 - - - - 0.17 2.4 E 1.38 1.13 1.19 0.25 0.25 1.2 - - - - 0.25 6 F 1.63 1.31 1.31 0.25 0.35 1.28 1.06 - - #4 0.44 12 G 1.88 1.56 1.50 0.30 0.40 1.41 1.25 - - #4 0.7 20 H 2.25 1.88 1.44 0.30 0.40 1.6 1.5 - - #4 0.8 36 J 2.63 2.19 1.56 0.40 0.40 1.85 - 1.75 2.19 #6 1.1 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/162-164 3/4 10/3/22, 1:23 AM Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA (162-164 Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/power/162-164 4/4
164D28 价格&库存
很抱歉,暂时无法提供与“164D28”相匹配的价格&库存,您可以联系我们找货
164D28
    • 1+62.429701+7.45996
    • 10+47.8018310+5.71202
    • 25+46.7560025+5.58705
    库存:15
