10/3/22, 1:23 AM
Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA (162-164 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Low Voltage PCB Mount - Low Profile - 1.1 VA to 36 VA 162-164 Series
Features
20 output voltages to choose from (5 - 120VAC R.M.S.)
Six VA size models available from - 1.1 to 36VA
Both series operate on 50/60 Hz current
Low profile, split bobbin design.
Dual winding secondaries, non-concentrically wound
Units are designed so that all windings must be used
Low primary to secondary coupling - no electrostatic shield required.
Choice of economical single primary 115V (164 series) or universal dual primary
115/230V (162 series) - either model 50/60 Hz operation.
High insulation - Hipot of 2,500V RMS.
Class B insulation - 130 degrees C.
No mounting hardware required on 1.1 and 2.4 VA sizes, two hole mounting on 6, 12 and
20VA sizes, four hole mounting on 36VA size (mounting screws not provided). P.C. board
mount with industry standard pin spacing.
c UL us recognized
https://www.hammfg.com/electronics/transformers/power/162-164
1/4
10/3/22, 1:23 AM
Part No
Part No
Single Primary
Dual Primary
Size
115V
115/230V
VA
Series
Parallel
164D10
162D10
1.1
10V C.T. @ .11A
5V @ .22A
164E10
162E10
2.4
10V C.T. @ .25A
5V @ .5A
164F10
162F10
6
10V C.T. @ .6A
5V @ 1.2A
164G10
162G10
12
10V C.T. @ 1.2A
5V @ 2.4A
164H10
162H10
10V C.T. @ 2A
5V @ 4.0A
Secondary (RMS)
164J10
162J10
36
10V C.T. @ 3.6A
5V @ 7.2A
164D12
162D12
1.1
12.6V C.T. @ .09A
6.3V @ .18A
164E12
162E12
2.4
12.6V C.T. @ .2A
6.3V @ .4A
164F12
162F12
6
12.6V C.T. @ .5A
6.3V @ 1.0A
164G12
162G12
12
12.6V C.T. @ 1.0A
6.3V @ 2.0A
164H12
162H12
12.6V C.T. @ 1.6A
6.3V @ 3.2A
164J12
162J12
36
12.6V C.T. @ 2.85A
6.3V @ 5.7A
164D16
162D16
1.1
16V C.T. @ .07A
8V @ .14A
164E16
162E16
2.4
16V C.T. @ .15A
8V @ .3A
164F16
162F16
6
16V C.T. @ .4A
8V @ .8A
164G16
162G16
12
16V C.T. @ .8A
8V @ 1.6A
164H16
162H16
16V C.T. @ 1.25A
8V @ 2.5A
164J16
162J16
36
16V C.T. @ 2.25A
8V @ 4.5A
164D20
162D20
1.1
20V C.T. @ .055A
10V @ .11A
164E20
162E20
2.4
20V C.T. @ .12A
10V @ .24A
164F20
162F20
6
20V C.T. @ .3A
10V @ .6A
164G20
162G20
12
20V C.T. @ .6A
10V @ 1.2A
164H20
162H20
20V C.T. @ 1A
10V @ 2.0A
164J20
162J20
36
20V C.T. @ 1.8A
10V @ 3.6A
164D24
162D24
1.1
24V C.T. @ .045A
12V @ .09A
164E24
162E24
2.4
24V C.T. @ .1A
12V @ .2A
2/4
10/3/22, 1:23 AM
Part No
Part No
Single Primary
Dual Primary
Size
115V
115/230V
VA
Series
Secondary (RMS)
Parallel
164F24
162F24
6
24V C.T. @ .25A
12V @ .5A
164G24
162G24
12
24V C.T. @ .5A
12V @ 1.0A
164H24
162H24
24V C.T. @ .8A
12V @ 1.6A
164J24
162J24
36
24V C.T. @ 1.5A
12V @ 3.0A
164D28
162D28
1.1
28V C.T. @ .04A
14V @ .08A
164E28
162E28
2.4
28V C.T. @ .085A
14V @ .17A
164F28
162F28
6
28V C.T. @ .2A
14V @ .4A
164G28
162G28
12
28V C.T. @ .42A
14V @ .84A
164H28
162H28
28V C.T. @ .7A
14V @ 1.4A
164J28
162J28
36
28V C.T. @ 1.3A
14V @ 2.6A
164D36
162D36
1.1
36V C.T. @ .03A
18V @ .06A
164E36
162E36
2.4
36V C.T. @ .065A
18V @ .13A
164F36
162F36
6
36V C.T. @ .17A
18V @ .34A
164G36
162G36
12
36V C.T. @ .35A
18V @ . 7A
164H36
162H36
36V C.T. @ .55A
18V @ 1.1A
164J36
162J36
36
36V C.T. @ 1A
18V @ 2.0A
164D48
162D48
1.1
48V C.T. @ .023A
24V @ .046A
164E48
162E48
2.4
48V C.T. @ .05A
24V @ .1A
164F48
162F48
6
48V C.T. @ .125A
24V @ .25A
164G48
162G48
12
48V C.T. @ .25A
24V @ .5A
164H48
162H48
48V C.T. @ .4A
24V @ .8A
164J48
162J48
36
48V C.T. @ .75A
24V @ 1.5A
164D56
162D56
1.1
56V C.T. @ .02A
28V @ .04A
164E56
162E56
2.4
56V C.T. @ .045A
28V @ .09A
164F56
162F56
6
56V C.T. @ .11A
28V @ .22A
164G56
162G56
12
56V C.T. @ .22A
28V @ .44A
164H56
162H56
56V C.T. @ .35A
28V @ .7A
164J56
162J56
36
56V C.T. @ .65A
28V @ 1.3A
164D120
162D120
1.1
120V C.T. @ .01A
60V @ .02A
164E120
162E120
2.4
120V C.T. @ .02A
60V @ .04A
60V @ .1A
164F120
162F120
6
120V C.T. @ .05A
164G120
162G120
12
120V C.T. @ .1A
60V @ .2A
164H120
162H120
120V C.T. @ .16A
60V @ .32A
164J120
162J120
36
120V C.T. @ .3A
60V @ .6A
Mechanical & Schematic Data
(VA)
Part Number
Size
Letter
L
W
H
A
Dimensions
B
C
M
N
P
Mounting
Screw
Weight
lbs.
1.1
D
1.38
1.13
15/16
0.25
0.25
1.2
0.17
2.4
E
1.38
1.13
1.19
0.25
0.25
1.2
0.25
6
F
1.63
1.31
1.31
0.25
0.35
1.28
1.06
#4
0.44
12
G
1.88
1.56
1.50
0.30
0.40
1.41
1.25
#4
0.7
H
2.25
1.88
1.44
0.30
0.40
1.6
1.5
#4
0.8
36
J
2.63
2.19
1.56
0.40
0.40
1.85
1.75
2.19
#6
1.1
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
3/4
10/3/22, 1:23 AM
4/4
很抱歉,暂时无法提供与“164F120”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+80.286051+9.59368
- 10+65.0962110+7.77859
- 25+61.0398425+7.29388
- 50+59.2028950+7.07437
