183E24
183E24
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 2.5VA THRU HOLE
183E24 数据手册
10/4/22, 8:42 AM Low Voltage PCB Mount - Universal - 2.5 VA to 56 VA (183 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage PCB Mount - Universal - 2.5 VA to 56 VA 183 Series Features Universal operation - dual primary. 115 or 230 VAC, 50/60 Hz current. 14 output voltages to choose from (5 - 36 VAC R.M.S.) Six VA size models available from - 2.5 to 56VA. Low profile, split bobbin with top shroud design. Dual winding secondaries, non-concentrically wound. Can be wired in series, parallel or used separately. Low primary to secondary coupling - no electrostatic shield required. High insulation - Hipot of 4,000V RMS. Class F insulation - 155 degrees C. Two hole mounting on 2.5, 5, 10 and 20VA sizes, four hole mounting on 30 and 56VA size (mounting screws not provided). P.C. board mount with industry standard pin spacing. Listings: cURus, CE and TUV. NOTE:  Products produced after January 1st, 2021 will no longer have a TUV Label, however we do carry plenty of TUV-labeled inventory.  Please contact us for more details. Mechanical & Schematic Data Mounting Dimensions (see tables below) Schematic https://www.hammfg.com/electronics/transformers/power/183 1/3 10/4/22, 8:42 AM Low Voltage PCB Mount - Universal - 2.5 VA to 56 VA (183 Series) - Hammond Mfg. Complete Connection diagram can be found here -   183 Connection Diagram Gallery       Dual Primary 115/230V Bulk Pack Size Part No. Part No. VA Series (see notes) Secondary (RMS) Parallel 183E10 183E10-BULK 2.5 10V C.T. @ 0.25A 5V @ 0.5A 183F10 183F10-BULK 5 10V C.T. @ 0.5A 5V @ 1A 183G10 183G10-BULK 10 10V C.T. @ 1A 5V @ 2A 183H10 183H10-BULK 20 10V C.T. @ 2A 5V @ 4A 183J10 183J10-BULK 30 10V C.T. @ 3A 5V @ 6A 183K10 183K10-BULK 56 10V C.T. @ 5.6A 5V @ 11.2A 183E12 183E12-BULK 2.5 12.6V C.T. @ 0.2A 6.3V @ 0.4A 183F12 183F12-BULK 5 12.6V C.T. @ 0.4A 6.3V @ 0.8A 183G12 183G12-BULK 10 12.6V C.T. @ 0.8A 6.3V @ 1.6A 183H12 183H12-BULK 20 12.6V C.T. @ 1.6A 6.3V @ 3.2A 183J12 183J12-BULK 30 12.6V C.T. @ 2.4A 6.3V @ 4.8A 183K12 183K12-BULK 56 12.6V C.T. @ 4.4A 6.3V @ 8.8A 183E16 183E16-BULK 2.5 16V C.T. @ 0.15A 8V @ 0.3A 183F16 183F16-BULK 5 16V C.T. @ 0.31A 8V @ 0.62A 183G16 183G16-BULK 10 16V C.T. @ 0.62A 8V @ 1.25A 183H16 183H16-BULK 20 16V C.T. @ 1.25A 8V @ 2.5A 183J16 183J16-BULK 30 16V C.T. @ 1.9A 8V @ 3.8A 183K16 183K16-BULK 56 16V C.T. @ 3.5A 8V @ 7A 183E20 183E20-BULK 2.5 20V C.T. @ 0.12A 10V @ 0.24A https://www.hammfg.com/electronics/transformers/power/183 2/3 10/4/22, 8:42 AM Low Voltage PCB Mount - Universal - 2.5 VA to 56 VA (183 Series) - Hammond Mfg. Dual Primary 115/230V Bulk Pack Size Part No. Part No. VA Series (see notes) Secondary (RMS) Parallel 183F20 183F20-BULK 5 20V C.T. @ 0.25A 10V @ 0.5A 183G20 183G20-BULK 10 20V C.T. @ 0.5A 10V @ 1A 183H20 183H20-BULK 20 20V C.T. @ 1.0A 10V @ 2A 183J20 183J20-BULK 30 20V C.T. @ 1.5A 10V @ 3A 183K20 183K20-BULK 56 20V C.T. @ 2.8A 10V @ 5.6A 183E24 183E24-BULK 2.5 24V C.T. @ 0.1A 12V @ 0.2A 183F24 183F24-BULK 5 24V C.T. @ 0.21A 12V @ 0.42A 183G24 183G24-BULK 10 24V C.T. @ 0.42A 12V @ 0.84A 183H24 183H24-BULK 20 24V C.T. @ 0.83A 12V @ 1.66A 183J24 183J24-BULK 30 24V C.T. @ 1.25A 12V @ 2.5A 183K24 183K24-BULK 56 24V C.T. @ 2.33A 12V @ 4.66A 183E28 183E28-BULK 2.5 28V C.T. @ 0.09A 14V @ 0.18A 183F28 183F28-BULK 5 28V C.T. @ 0.18A 14V @ 0.36A 183G28 183G28-BULK 10 28V C.T. @ 0.36A 14V @ 0.72A 183H28 183H28-BULK 20 28V C.T. @ 0.72A 14V @ 1.44A 183J28 183J28-BULK 30 28V C.T. @ 1.06A 14V @ 2.12A 183K28 183K28-BULK 56 28V C.T. @ 2A 14V @ 4A 183E36 183E36-BULK 2.5 36V C.T. @ 0.07A 18V @ 0.14A 183F36 183F36-BULK 5 36V C.T. @ 0.14A 18V @ 0.28A 183G36 183G36-BULK 10 36V C.T. @ 0.28A 18V @ 0.56A 183H36 183H36-BULK 20 36V C.T. @ 0.56A 18V @ 1.12A 183J36 183J36-BULK 30 36V C.T. @ 0.82A 18V @ 1.64A 183K36 183K36-BULK 56 36V C.T. @ 1.56A 18V @ 3.12A Notes: when connecting the secondaries in series (pin 9 connected to pin 10) - that connection acts as a C.T. (center tap). Mechanical & Schematic Data Pin Size Mtg. Size (VA) L W H A Dimensions B C M N P (Square) Screw Weight lbs. 2.5 1.63 1.44 1.13 0.20 0.25 1.00 1.06 - - 0.025 #4 0.17 5 1.63 1.44 1.38 0.20 0.40 1.00 1.06 - - 0.025 #4 0.37 10 1.88 1.56 1.38 0.20 0.40 1.14 1.25 - - 0.036 #4 0.53 20 2.25 1.88 1.63 0.40 0.40 1.46 1.50 - - 0.036 #4 0.9 30 2.63 2.19 1.56 0.55 0.28 1.68 - 1.75 2.19 0.045 #6 1.15 56 3.00 2.50 1.81 0.60 0.30 1.90 - 2.00 2.50 0.045 #6 1.7 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/183 3/3
183E24
物料型号:183系列变压器,包括多个型号,如183E10、183F10等,每个型号具有不同的输出电压和电流。
器件简介:这些变压器具有双原边设计,可接受115或230VAC,50/60Hz的输入,并提供14种不同的输出电压选项。它们具有低轮廓、分体式骨架和顶部护罩设计。
引脚分配:文档中提到了引脚编号,但未在文档中直接显示。引脚分配的详细信息可以在183连接图找到。
参数特性:变压器提供多种输出电压和电流组合,具有高绝缘等级,Hipot测试达到4000V RMS,绝缘等级为F级,最高工作温度为155°C。
功能详解:变压器的次级绕组可以非同心地绕制,可以串联、并联或单独使用,以满足不同的电压和电流需求。
应用信息:适用于需要低压电源的各种应用,如电子设备、电源适配器等。
封装信息:提供了不同功率大小的变压器的安装尺寸、引脚大小、安装螺丝和重量等详细信息。
183E24 价格&库存
很抱歉,暂时无法提供与“183E24”相匹配的价格&库存,您可以联系我们找货
