229E230
229E230
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 2VA THRU HOLE
229E230 数据手册
www.hammondmfg.com 229E230 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 1.56” (40 mm) B 1.88” (48 mm) C 0.65” (17 mm) D 0.38” (10 mm) D1 0.38” (10 mm) E 1.60” (41 mm) PC Board Spacing 0.75” (19 mm) Pin Size 0.02” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 2 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 230V C.T. @ 10ma Secondary (RMS) Parallel 115V @ 20ma Regulation 30% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229E230 价格&库存
很抱歉,暂时无法提供与“229E230”相匹配的价格&库存,您可以联系我们找货
