Power
Filament & L.V. Rectifier Use - Single Primary (166 Series)
OPEN STYLE
FILAMENT & L.V. RECTIFIER USE
TRANSFORMERS
• Economical single primary 115 VAC, 60 Hz. or 117 VAC,
50/60 Hz. (see tables). If you require dual primary
117/234 operation, see our 266 series)
• All secondaries center tapped, VAC (RMS)
• Open style, channel bracket, two hole chassis mount.
• Minimum 6" long leads.
• Dual bobbin design - no electrostatic shield required.
• We use Class B insulation (130 degrees, C) for extra
protection - UL listed as a Class A (105 degree, C)
design.
• Hi-Pot test of 2,000V RMS.
• UL listed.
• CSA certified.
Dimension Table "C" Mount
Mtg.
Style
C0H
C1H
C2H
C3H
C4H
C5H
C6H
C7H
C8H
C9H
C10H
C11H
C12H
C13H
C14H
C15H
C16H
Transformer Schematic
Grn
Primary
Grn/Yel
Blk
Grn
Secondary
Blk
CANADA
D
1.06
1.38
1.75
1.75
2.00
2.00
2.38
2.38
2.81
2.81
2.81
3.13
3.13
3.13
3.56
3.56
4.00
Mtg. Hole
(Inches)
0.125
0.125
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.203
EUROPE
Guelph, Ontario (519) 822-2960
St. Laurent, Quebec (514) 343-9010
www.hammondmfg.com
Cheektowaga, NY (716) 630-7030
USA
A
1.35
1.63
2.06
2.06
2.38
2.38
2.81
2.81
3.25
3.25
3.25
3.69
3.69
3.69
4.03
4.03
4.50
Dimensions
(Inches)
B
C
0.69 0.69
0.88 0.81
1.25 1.19
1.38 1.19
1.38 1.38
1.50 1.38
1.50 1.69
1.63 1.69
1.63 2.00
1.75 2.00
2.00 2.00
1.88 2.31
2.00 2.31
2.13 2.31
2.25 2.63
2.50 2.63
2.50 3.00
Basingstoke, UK 01256 812812
AUSTRALIA
Queenstown, Australia 61-8-8240-2244
VA
Primary
166F2
166G2
166J2
166K2
166L2
166M2
166Q2
166S2
166F5
166G5
166J5
166L5
166MS
166R5
166RS
166S5
166U5
166V5
166E6
166F6
166G6
166J6
166K6
166K6B
166L6
166M6
166N6
166Q6
166S6
166G7
166U7
166G8
166J8
166L8
166M8
166N8
166G9
166F10
166G10
166J10
166L10
166M10
166N10
166P10
166R10
166S10
166P11
166S11
166C12
166E12
166F12B
166F12C
166GD12
166JA12
166K12
166JB12
0.63
1.25
2.5
3.75
6.25
7.5
15
25
1.25
2.5
5
10
15
40
40
50
75
100
0.95
1.89
3.78
6.3
7.56
7.56
12.6
18.9
25.2
37.8
63
4.9
112.5
4
8.5
17
25.5
34
4.5
3
5
10
40
50
80
100
55
110
0.63
1.8
3.6
4.2
8.4
12
14.4
14.4
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
117 V 50/60 Hz.
115 V 60 Hz.
117 V 50/60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
117 V 50/60 Hz.
115 V 60 Hz
115 V 60 Hz.
117 V 50/60 Hz.
Secondary (R.M.S.)
VAC
Amps
2.5 C.T.
0.25
2.5 C.T.
0.5
2.5 C.T.
1
2.5 C.T.
1.5
2.5 C.T.
2.5
2.5 C.T.
3
2.5 C.T.
6
2.5 C.T.
10
5 C.T.
0.25
5 C.T.
0.5
5 C.T.
1
5 C.T.
2
5 C.T.
3
5 C.T.
8
5 C.T.
8
5 C.T.
10
5 C.T.
15
5 C.T.
6.3 C.T.
0.15
6.3 C.T.
0.3
6.3 C.T.
0.6
6.3 C.T.
1
6.3 C.T.
1.2
6.3 C.T.
1.2
6.3 C.T.
2
6.3 C.T.
3
6.3 C.T.
4
6.3 C.T.
6
6.3 C.T.
10
7 C.T.
0.7
7.5 C.T.
15
8 C.T.
0.5
8.5 C.T.
1
8.5 C.T.
2
8.5 C.T.
3
8.5 C.T.
4
9 C.T.
0.5
10 C.T.
0.3
10 C.T.
0.5
10 C.T.
1
10 C.T.
2
10 C.T.
3
10 C.T.
4
10 C.T.
5
10 C.T.
8
10 C.T.
10
11 C.T.
5
11 C.T.
10
6.3/12.6 C.T.
.1/.05
12 C.T.
0.15
12 C.T.
0.3
12 C.T.
0.35
12
0.7
12 C.T.
1
12 C.T.
1.2
12 C.T.
1.2
Dim
Ref.
C2H
C2H
C3H
C4H
C6H
C6H
C8H
C12H
C2H
C3H
C5H
C7H
C9H
C12H
C16H
C13H
C14H
C16H
C2H
C3H
C4H
C6H
C6H
C6H
C7H
C10H
C9H
C12H
C14H
C5H
C16H
C4H
C6H
C8H
C9H
C10H
C4H
C3H
C5H
C7H
C9H
C10H
C12H
C13H
C15H
C16H
C13H
C16H
C2H
C3H
C4H
C4H
C7H
C7H
C8H
C9H
Part No.
VA
166LA12
24
115 V 60 Hz.
166N12B
48
117 V 50/60 Hz.
166F12
3.78
115 V 60 Hz.
166G12
6.3
115 V 60 Hz.
166J12
12.6
115 V 60 Hz.
166K12B 18.9 117 V 50/60 Hz.
166L12B 25.2 117 V 50/60 Hz.
166L12
31.5
115 V 60 Hz.
166M12
37.8 117 V 50/60 Hz.
166N12
50.4
115 V 60 Hz.
166Q12
75.6
115 V 60 Hz.
166R12 100.8
115 V 60 Hz.
166E14
2.1
115 V 60 Hz.
166G14
7
115 V 60 Hz.
166J14
14
115 V 60 Hz.
166L14
28
115 V 60 Hz.
166Q14
84
115 V 60 Hz.
166F16
4
115 V 60 Hz.
166G16
8
115 V 60 Hz.
166J16
16
115 V 60 Hz.
166L16
35.2
115 V 60 Hz.
166M16
48
115 V 60 Hz.
166B18
0.54
115 V 60 Hz.
166E18
5.4
115 V 60 Hz.
166K18
27
115 V 60 Hz.
166M18
54
115 V 60 Hz.
166P18
90
115 V 60 Hz.
166D20
2
115 V 60 Hz.
166E20
3
115 V 60 Hz.
166F20
6
115 V 60 Hz.
166G20
10
115 V 60 Hz.
166J20
115 V 60 Hz.
166L20
40
115 V 60 Hz.
166L22
44
115 V 60 Hz.
166A24
0.63
115 V 60 Hz.
166C24
2.04
115 V 60 Hz.
166EA24
4.8
115 V 60 Hz.
166FB24
9.6 117 V 50/60 Hz.
166GD24B 16.8 117 V 50/60 Hz.
166J24
24
117 V 50/60 Hz.
166JB24
24
115 V 60 Hz.
166L24
48
115 V 60 Hz.
166M24
72
115 V 60 Hz.
166N24
96
115 V 60 Hz.
166D25
2.5
115 V 60 Hz.
166E25
3.75
115 V 60 Hz.
166F25
7.5
115 V 60 Hz.
166G25
12.5
115 V 60 Hz.
166J25
25
115 V 60 Hz.
166J25B
25
117 V 50/60 Hz.
166K25
37.5
115 V 60 Hz.
166L25
50
115 V 60 Hz.
166M25
75
115 V 60 Hz.
166L25B 50.4 115 V 50/60 Hz.
166F28
7
115 V 60 Hz.
166G28
14
115 V 60 Hz.
EUROPE
AUSTRALIA
Primary
Secondary (R.M.S.)
VAC
Amps
12 C.T.
2
12 C.T.
4
12.6 C.T.
0.3
12.6 C.T.
0.5
12.6 C.T.
1
12.6 C.T.
1.5
12.6 C.T.
2
12.6 C.T.
2.5
12.6 C.T.
3
12.6 C.T.
4
12.6 C.T.
6
12.6 C.T.
8
14 C.T.
0.15
14 C.T.
0.5
14 C.T.
1
14 C.T.
2
14 C.T.
6
16 C.T.
0.25
16 C.T.
0.50
16 C.T.
1
16 C.T.
2.2
16 C.T.
3
9/18 C.T.
.06/.03
18 C.T.
0.3
18 C.T.
1.5
18 C.T.
3
18 C.T.
5
20 C.T.
0.1
20 C.T.
0.15
20 C.T.
0.3
20 C.T.
0.5
20 C.T.
1
20 C.T.
2
22 C.T.
2
12.6/25.2 C.T. .05/.025
24 C.T.
0.085
24 C.T.
0.2
24 C.T.
0.4
24 C.T.
0.7
24 C.T.
1
24 C.T.
1
24 C.T.
2
24 C.T.
3
24 C.T.
4
25 C.T.
0.1
25 C.T.
0.15
25 C.T.
0.3
25 C.T.
0.5
25 C.T.
1
25 C.T.
1
25 C.T.
1.5
25 C.T.
2
25 C.T.
3
25.2 C.T.
2
28 C.T.
0.25
28 C.T.
0.5
Dim
Ref.
C9H
C12H
C4H
C6H
C7H
C10H
C10H
C10H
C13H
C13H
C14H
C16H
C3H
C6H
C7H
C10H
C15H
C4H
C6H
C8H
C10H
C13H
C2H
C5H
C9H
C13H
C15H
C3H
C3H
C5H
C7H
C9H
C11H
C13H
C2H
C3H
C5H
C7H
C9H
C10H
C9H
C13H
C14H
C16H
C3H
C4H
C6H
C7H
C9H
C10H
C11H
C13H
C14H
C14H
C6H
C7H
CANADA
www.hammondmfg.com
21
USA
Power
Part No.
Power
Part No.
VA
Primary
166J28
166L28
166E30
166F30
166G30
166J33
166K35
166E36
166F36
166G36
166J36
166L42
166E44
166F44
166G44
166J44
166M48
166C50
166F50
166G50
166J50
166L50
166G60
166M72
166G80
166G100
166F120
28
56
4.5
7.5
15
33
52.5
5.4
10.8
18
36
84
6.6
11
22
44
144
3.75
15
25
50
100
30
216
40
50
36
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
117 V 50/60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
117 V 50/60 Hz.
115 V 60 Hz.
115 V 60 Hz.
115 V 60 Hz.
Secondary (R.M.S.)
VAC
Amps
28 C.T.
1
28 C.T.
2
30 C.T.
0.15
30 C.T.
0.25
30 C.T.
0.5
33 C.T.
1
35 C.T.
1.5
36 C.T.
0.15
36 C.T.
0.3
36 C.T.
0.5
36 C.T.
1
42 C.T.
2
44 C.T.
0.15
44 C.T.
0.25
44 C.T.
0.5
44 C.T.
1
48 C.T.
3
50 C.T.
0.075
50 C.T.
0.3
50 C.T.
0.5
50 C.T.
1
50 C.T.
2
60 C.T.
0.5
72 C.T.
3
80 C.T.
0.5
100 C.T.
0.5
120 C.T.
0.3
Dim
Ref.
C10H
C13H
C4H
C6H
C8H
C10H
C13H
C5H
C7H
C8H
C11H
C15H
C6H
C7H
C9H
C12H
B1H
C4H
C8H
C9H
C13H
C16H
C10H
B2H
C11H
C13H
C11H
Mtg.
Style
C0H
C1H
C2H
C3H
C4H
C5H
C6H
C7H
C8H
C9H
C10H
C11H
C12H
C13H
C14H
C15H
C16H
A
1.35
1.63
2.06
2.06
2.38
2.38
2.81
2.81
3.25
3.25
3.25
3.69
3.69
3.69
4.03
4.03
4.50
Dimensions
(Inches)
B
C
0.69 0.69
0.88 0.81
1.25 1.19
1.38 1.19
1.38 1.38
1.50 1.38
1.50 1.69
1.63 1.69
1.63 2.00
1.75 2.00
2.00 2.00
1.88 2.31
2.00 2.31
2.13 2.31
2.25 2.63
2.50 2.63
2.50 3.00
D
1.06
1.38
1.75
1.75
2.00
2.00
2.38
2.38
2.81
2.81
2.81
3.13
3.13
3.13
3.56
3.56
4.00
Mtg. Hole
(Inches)
0.125
0.125
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.187
0.203
Dimension Table "B" Mount
Mtg.
Style
B1H
B2H
A
3.44
3.75
Dimensions
(Inches)
B
C
D
2.98 4.13 2.75
3.56 4.50 3.00
E
2.38
3.00
Mtg. Slot
(Inches)
0.203 x 0.375
0.203 x 0.375
CANADA
EUROPE
www.hammondmfg.com
22
USA
AUSTRALIA
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hammond:
166J14 166J36 166J12 166J33 166J10 166J16 166J50 166Q14 166Q12 166K18 166K12 166K35 166K25
166J28 166J25 166J20 166J44 166L14 166L16 166L12 166L50 166L10 166L42 166A24 166R10 166R12
166B18 166Q6 166K2 166M2 166K6 166S6 166M8 166Q2 166U7 166S2 166U5 166S5 166RS 166MS
166N24 166C24 166F12 166F20 166F25 166F50 166F10 166F44 166F36 166F30 166F28 166F16 166G44
166G25 166G60 166G50 166G28 166G36 166G20 166G12 166G30 166G16 166G10 166G14 166N10
166N12 166G100 166M18 166M10 166M25 166M16 166C12 166S11 166C50 166L25 166D25 166L28
166L22 166D20 166L20 166L24 166G80 166G9 166L2 166J2 166L5 166N6 166G8 166F2 166L8 166G2
166J6 166J8 166N8 166G7 166G5 166G6 166F5 166L6 166V5
很抱歉,暂时无法提供与“166JB24”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+153.965201+19.84910
- 10+144.7541010+18.66160
- 25+128.6198025+16.58160
- 50+124.5952050+16.06280
- 100+120.64240100+15.55320
- 250+115.64760250+14.90920
- 500+112.05420500+14.44600
- 国内价格 香港价格
- 1+180.324941+23.30686
