229B20
229B20
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 12VA THRU HOLE
229B20 数据手册
www.hammondmfg.com 229B20 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.00” (51 mm) B 2.50” (64 mm) C 1.07” (27 mm) D 0.50” (13 mm) D1 0.50” (13 mm) E 2.00” (51 mm) PC Board Spacing 1.25” (32 mm) Pin Size 0.02” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 12 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 20V C.T. @ 600ma Secondary (RMS) Parallel 10V @ 1.2A Regulation 20% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229B20 价格&库存
很抱歉,暂时无法提供与“229B20”相匹配的价格&库存,您可以联系我们找货
229B20
  • 1+180.351291+22.55782
  • 10+162.4335810+20.31672
  • 25+155.7391425+19.47940
  • 50+150.8375550+18.86633
  • 100+146.07227100+18.27030
  • 250+139.97993250+17.50828
  • 500+135.52430500+16.95099
库存:21
