229B12
229B12
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 12VA THRU HOLE
229B12 数据手册
www.hammondmfg.com 229B12 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.00” (51 mm) B 2.50” (64 mm) C 1.07” (27 mm) D 0.50” (13 mm) D1 0.50” (13 mm) E 2.00” (51 mm) PC Board Spacing 1.25” (32 mm) Pin Size 0.02” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 12 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 12.6V C.T. @ 900ma Secondary (RMS) Parallel 6.3V @ 1.8a Regulation 20% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229B12 价格&库存
很抱歉,暂时无法提供与“229B12”相匹配的价格&库存,您可以联系我们找货
229B12
    • 1+171.863461+20.53660
    • 10+151.6584610+18.12223
    • 25+146.6082025+17.51875
    • 50+131.4395550+15.70620
    • 100+126.38482100+15.10219
    库存:3
