229B56
229B56
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 12VA THRU HOLE
229B56 数据手册
www.hammondmfg.com 229B56 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.00” (51 mm) B 2.50” (64 mm) C 1.07” (27 mm) D 0.50” (13 mm) D1 0.50” (13 mm) E 2.00” (51 mm) PC Board Spacing 1.25” (32 mm) Pin Size 0.02” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 12 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 56V C.T. @ 200ma Secondary (RMS) Parallel 28V @ 400ma Regulation 20% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229B56 价格&库存
很抱歉,暂时无法提供与“229B56”相匹配的价格&库存,您可以联系我们找货
