186E48
186E48
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 57.6VA CHAS MNT
186E48 数据手册
10/3/22, 1:36 AM Low Voltage Solder or Quick Connect Terminals - 2.4 VA to 102 VA (186-187 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage Solder or Quick Connect Terminals - 2.4 VA to 102 VA 186-187 Series Chassis Mount - 115 & 115/230 V Primary Features Choice of two primaries: Single Primary 115VAC (187 series) or Dual Primary 115/230VAC (186 series). Either series operates on 50/60 Hz. Combination solder or quick connect terminals. Split bobbin construction eliminates the need for an electrostatic shield. Hi-pot tested to 2 KV RMS. Economical open style, channel frame - chassis mount design Insulation material - Class B or 130 C Lower temperature rise designed not to exceed Class A for longer life. UL listed (# E207860) Type 3AH CSA Certified A wiring diagram for this series can be downloaded here. Gallery   https://www.hammfg.com/electronics/transformers/power/186-187     1/4 10/3/22, 1:36 AM Low Voltage Solder or Quick Connect Terminals - 2.4 VA to 102 VA (186-187 Series) - Hammond Mfg. Dimensions Part No. Part No. Secondary Mounting Depth Single Primary Dual Primary (R.M.S.) Current VA Length (Not Including Terminals) Height Centers To Terminal 115 VAC 115/230 VAC VAC (Amps) Rating L B C D E 187A10 10V C.T. 0.25 2.5 2.06 1.06 1.18 1.75 1.44 187B10 186B10 10V C.T. 0.6 6 2.37 1.25 1.37 2.00 1.62 187C10 186C10 10V C.T. 1.2 12 2.81 1.37 1.62 2.37 1.73 187D10 186D10 10V C.T. 3 30 3.25 1.68 1.93 2.81 2.06 187E10 186E10 10V C.T. 5 50 3.68 1.81 2.25 3.12 2.19 187F10 186F10 10V C.T. 10 100 4.03 2.25 2.56 3.50 2.62 187A12 - Depth 12.6V C.T. 0.19 2.5 2.06 1.06 1.18 1.75 1.44 187B12 186B12 12.6V C.T. 0.5 6.3 2.37 1.25 1.37 2.00 1.62 187C12 186C12 12.6V C.T. 1 12.6 2.81 1.37 1.62 2.37 1.73 187D12 186D12 12.6V C.T. 2.5 31.5 3.25 1.68 1.93 2.81 2.06 https://www.hammfg.com/electronics/transformers/power/186-187 2/4 10/3/22, 1:36 AM Low Voltage Solder or Quick Connect Terminals - 2.4 VA to 102 VA (186-187 Series) - Hammond Mfg. Dimensions Part No. Part No. Secondary Mounting Depth Single Primary Dual Primary (R.M.S.) Current VA Length (Not Including Terminals) Height Centers To Terminal 115 VAC 115/230 VAC VAC (Amps) Rating L B C D E 187E12 186E12 12.6V C.T. 4 50.4 3.68 1.81 2.25 3.12 2.19 187F12 186F12 12.6V C.T. 8 100.8 4.03 2.25 2.56 3.50 2.62 16V C.T. 0.15 2.4 2.06 1.06 1.18 1.75 1.44 187A16 - Depth 187B16 186B16 16V C.T. 0.4 6.4 2.37 1.25 1.37 2.00 1.62 187C16 186C16 16V C.T. 0.8 12.8 2.81 1.37 1.62 2.37 1.73 187D16 186D16 16V C.T. 2 32 3.25 1.68 1.93 2.81 2.06 187E16 186E16 16V C.T. 3.5 56 3.68 1.81 2.25 3.12 2.19 187F16 186F16 16V C.T. 6.25 100 4.03 2.25 2.56 3.50 2.62 20V C.T. 0.12 2.4 2.06 1.06 1.18 1.75 1.44 187A20 - 187B20 186B20 20V C.T. 0.3 6 2.37 1.25 1.37 2.00 1.62 187C20 186C20 20V C.T. 0.6 12 2.81 1.37 1.62 2.37 1.73 187D20 186D20 20V C.T. 1.5 30 3.25 1.68 1.93 2.81 2.06 187E20 186E20 20V C.T. 2.8 56 3.68 1.81 2.25 3.12 2.19 187F20 186F20 20V C.T. 5 100 4.03 2.25 2.56 3.50 2.62 24V C.T. 0.1 2.4 2.06 1.06 1.18 1.75 1.44 187A24 - 187B24 186B24 24V C.T. 0.25 6 2.37 1.25 1.37 2.00 1.62 187C24 186C24 24V C.T. 0.5 12 2.81 1.37 1.62 2.37 1.73 187D24 186D24 24V C.T. 1.25 30 3.25 1.68 1.93 2.81 2.06 187E24 186E24 24V C.T. 2.4 57.6 3.68 1.81 2.25 3.12 2.19 187F24 186F24 24V C.T. 4 96 4.03 2.25 2.56 3.50 2.62 28V C.T. 0.08 2.4 2.06 1.06 1.18 1.75 1.44 187A28 - 187B28 186B28 28V C.T. 0.2 5.6 2.37 1.25 1.37 2.00 1.62 187C28 186C28 28V C.T. 0.42 12 2.81 1.37 1.62 2.37 1.73 187D28 186D28 28V C.T. 1.07 30 3.25 1.68 1.93 2.81 2.06 187E28 186E28 28V C.T. 2 56 3.68 1.81 2.25 3.12 2.19 187F28 186F28 28V C.T. 3.57 100 4.03 2.25 2.56 3.50 2.62 36V C.T. 0.06 2.34 2.06 1.06 1.18 1.75 1.44 187A36 - 187B36 186B36 36V C.T. 0.17 6.12 2.37 1.25 1.37 2.00 1.62 187C36 186C36 36V C.T. 0.35 12.6 2.81 1.37 1.62 2.37 1.73 187D36 186D36 36V C.T. 0.85 30.6 3.25 1.68 1.93 2.81 2.06 187E36 186E36 36V C.T. 1.5 54 3.68 1.81 2.25 3.12 2.19 187F36 186F36 36V C.T. 2.8 100.8 4.03 2.25 2.56 3.50 2.62 48V C.T. 0.05 2.4 2.06 1.06 1.18 1.75 1.44 187A48 - 187B48 186B48 48V C.T. 0.12 6 2.37 1.25 1.37 2.00 1.62 187C48 186C48 48V C.T. 0.25 12 2.81 1.37 1.62 2.37 1.73 187D48 186D48 48V C.T. 0.62 30 3.25 1.68 1.93 2.81 2.06 187E48 186E48 48V C.T. 1.2 57.6 3.68 1.81 2.25 3.12 2.19 187F48 186F48 48V C.T. 2 96 4.03 2.25 2.56 3.50 2.62 56V C.T. 0.04 2.5 2.06 1.06 1.18 1.75 1.44 187A56 - 187B56 186B56 56V C.T. 0.11 6.16 2.37 1.25 1.37 2.00 1.62 187C56 186C56 56V C.T. 0.21 12.3 2.81 1.37 1.62 2.37 1.73 187D56 186D56 56V C.T. 0.53 30 3.25 1.68 1.93 2.81 2.06 187E56 186E56 56V C.T. 1 56 3.68 1.81 2.25 3.12 2.19 187F56 186F56 56V C.T. 1.8 100.8 4.03 2.25 2.56 3.50 2.62 120V C.T. 0.02 2.4 2.06 1.06 1.18 1.75 1.44 0.05 6 2.37 1.25 1.37 2.00 1.62 187A120 - 187B120 186B120 120V C.T. 187C120 186C120 120V C.T. 0.1 12 2.81 1.37 1.62 2.37 1.73 187D120 186D120 120V C.T. 0.25 30 3.25 1.68 1.93 2.81 2.06 187E120 186E120 120V C.T. 0.5 60 3.68 1.81 2.25 3.12 2.19 187F120 186F120 120V C.T. 0.85 102 4.03 2.25 2.56 3.50 2.62 Tags: 3AH https://www.hammfg.com/electronics/transformers/power/186-187 Data subject to change without notice 3/4 10/3/22, 1:36 AM Low Voltage Solder or Quick Connect Terminals - 2.4 VA to 102 VA (186-187 Series) - Hammond Mfg. © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/186-187 4/4
186E48
物料型号:186-187系列 器件简介:Hammond Manufacturing生产的低压变压器,适用于115/230V交流电,50/60Hz,提供单相115VAC(187系列)或双相115/230VAC(186系列)。 引脚分配:提供组合焊接或快速连接端子,具有分体式线圈构造,无需静电屏蔽。 参数特性:高电位测试至2kV RMS,经济实惠的开放式设计,UL认证(#E207860)Type 3AH,绝缘材料为Class B或130°C,设计以不超过Class A的温度上升,以延长使用寿命。 功能详解:文档提供了详细的安装尺寸、安装中心、端子到端子的深度等信息。 应用信息:适用于需要低压电源转换的电子设备。 封装信息:文档提供了不同型号的变压器的尺寸和额定功率信息,以及快速连接或焊接端子的详细图纸。
186E48 价格&库存
很抱歉,暂时无法提供与“186E48”相匹配的价格&库存,您可以联系我们找货
