XF-10200
XF-10200
    AMGIS
    XFRMR SEMI-TORO 1.6VA CHAS MOUNT
XF-10200 数据手册
LOW PROFILE MINIATURE TRANSFORMERS Electrical Specification @20°C Amgis P/N XF-10200 XF-10201 XF-10202 1.6 VA XF-10203 XF-10204 XF-10205 Rated Secondary Voltage/Current 2 x 7V 114 mA 2 x 9V 89 mA 2 x 12V 67 mA 2 x 15V 53 mA 2 x 18V 44 mA 2 x 22V 36 mA No load voltage (Uo) 2 x 8.94V 2 x 11.63V 2 x 15.43V 2 x 19.30V 2 x 23.41V 2 x 28.19V XF-10206 XF-10207 XF-10208 3.2 VA XF-10209 XF-10210 XF-10211 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 229 178 133 107 89 73 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 10.20V 13.00V 17.30V 1.5(mA) 21.40V 25.70V 31.30V XF-10212 XF-10213 XF-10214 5.0 VA XF-10215 XF-10216 XF-10217 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 357 278 208 167 139 114 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 9.92V 12.72V 17.11V 2.0(mA) 21.37V 25.49V 31.19V XF-10218 XF-10219 XF-10220 7.0 VA XF-10221 XF-10222 XF-10223 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 500 389 292 233 194 159 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 9.09V 11.71V 15.75V 3.0(mA) 19.61V 23.72V 28.52V XF-10224 XF-10225 XF-10226 10.0 VA XF-10227 XF-10228 XF-10229 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 714 556 417 333 278 227 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 8.30V 10.80V 14.40V 3.0(mA) 18.00V 21.70V 26.30V XF-10230 XF-10231 XF-10232 15.0 VA XF-10233 XF-10234 XF-10235 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 1071 833 625 500 417 341 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 8.90V 11.10V 14.80V 4.0(mA) 18.50V 22.20V 27.20V XF-10236 XF-10237 XF-10238 25.0 VA XF-10239 XF-10240 XF-10241 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 1786 1389 1042 833 694 568 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 8.30V 10.70V 14.24V 5.0(mA) 17.80V 21.40V 26.20V XF-10242 XF-10243 XF-10244 35.0 VA XF-10245 XF-10246 XF-10247 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 2500 1944 1458 1167 972 795 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 8.24V 10.60V 14.00V 7.0(mA) 17.7 17.60V 20.90V 25.70V XF-10248 XF-10249 XF-10250 50.0 VA XF-10251 XF-10252 XF-10253 2x 2x 2x 2x 2x 2x 7V 9V 12V 15V 18V 22V 3571 2778 2083 1667 1389 1136 mA mA mA mA mA mA 2x 2x 2x 2x 2x 2x 8.10V 10.40V 13.80V 8.0(mA) 15.5 17.30V 20.70V 25.40V Rating All dimensions are in mm Data subject to change without prior notice No Load Reg. % current 1.0(mA) 29 41 45 34 20 23 Temp rise in °C 10 20 29 25 24 27 ƞ in % 77 70 70 74 82 81 Wt. in g Coil size OD x ID x H 71 37.5 x 7.0 x 17.0 89 42.0 x 7.0 x 17.5 115 47.0 x 6.0 x 18.0 145 47.0 x 6.8 x 21.5 216 53.5 x 6.8 x 23.5 262 57.5 x 7.0 x 24.0 SCHEMATIC: * Primaries & Secondaries are intended for both series and parallel connections FINISHED ASSEMBLY: ADDITIONAL FEATURES: -Primary intended to use in 115V or 230V @ 50/60Hz -UL recognition for class A insulation -UL recognized to UL5085-1 and UL5085-2, UL file E310463 -C-UL recognized to CSA C22.2 no 66. UL file E310403 19 28 31 30 84 85 86 388 58.0 x 13.8 x 34.5 453 72.0 x 17.0 x 33.5 670 78.0 x 22.5 x 35.0 -Design construction meet UL 1950, VDE 0805, IEC 950, eeeeeeeeeeeEe EN60950 -Hipot testing between Pri to Sec 4000V (VDE0550) -Maximum ambient temperature +60°C -Center hole Potted for M4 bolt
XF-10200
1. 物料型号:文档列出了不同型号的变压器,如XF-102002x7V、XF-102012x9V等,每个型号对应不同的额定次级电压和电流。
2. 器件简介:文档提供了变压器的电气规格,包括额定功率、空载电压、空载电流、调节百分比、温升、重量和线圈尺寸。
3. 引脚分配:文档中提到了变压器的引脚分配,例如P1° S1 Black Green.oV OV 115V VA Red Blue (50-60Hz) P2 S2,表示输入和输出端的连接方式。
4. 参数特性:列出了不同额定功率下的变压器参数,如空载电流、次级电压、调节百分比、温升、重量等。
5. 功能详解:文档中提到了变压器的多种特性,如适用于串联和并联连接、UL认证、绝缘等级、环境温度限制等。
6. 应用信息:虽然没有直接提到应用信息,但从电气规格可以推断这些变压器适用于需要低噪声、高效率和紧凑尺寸的电源应用。
7. 封装信息:提供了变压器的物理尺寸,如外径、内径和高度。
XF-10200 价格&库存
很抱歉,暂时无法提供与“XF-10200”相匹配的价格&库存,您可以联系我们找货
XF-10200
  • 1+215.182331+27.96846
  • 10+193.7889810+25.18785
  • 30+184.2342130+23.94596
  • 50+179.9323550+23.38682
  • 100+174.23674100+22.64653
  • 250+166.95655250+21.70028
  • 500+161.63442500+21.00854
库存:2
