229C56
229C56
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 24VA THRU HOLE
229C56 数据手册
www.hammondmfg.com 229C56 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.25” (57 mm) B 2.87” (73 mm) C 1.25” (32 mm) D 0.60” (15 mm) D1 0.53” (13 mm) E 1.90” (48 mm) PC Board Spacing 1.50” (38 mm) Pin Size 0.04” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 24 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 56V C.T. @ 425ma Secondary (RMS) Parallel 28V @ 850ma Regulation 15% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229C56 价格&库存
很抱歉,暂时无法提供与“229C56”相匹配的价格&库存,您可以联系我们找货
229C56
    • 1+231.156091+27.62169
    • 10+198.3571210+23.70242
    • 25+189.5930725+22.65517
    • 50+184.1408150+22.00366
    • 100+179.53202100+21.45294
    • 250+174.51559250+20.85351
    • 500+171.39649500+20.48080
    库存:1
