229C34
229C34
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 24VA THRU HOLE
229C34 数据手册
www.hammondmfg.com 229C34 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.25” (57 mm) B 2.87” (73 mm) C 1.25” (32 mm) D 0.60” (15 mm) D1 0.53” (13 mm) E 1.90” (48 mm) PC Board Spacing 1.50” (38 mm) Pin Size 0.04” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 24 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 34V C.T. @ 700ma Secondary (RMS) Parallel 17V @ 1.4A Regulation 15% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229C34 价格&库存
很抱歉,暂时无法提供与“229C34”相匹配的价格&库存,您可以联系我们找货
229C34
    • 1+228.829261+27.34365
    • 10+196.2401210+23.44945
    • 25+187.5691525+22.41333
    • 50+182.1800450+21.76936
    • 100+177.62319100+21.22485
    • 250+172.66700250+20.63261
    • 500+169.58703500+20.26458
    库存:1
