166F6
166F6
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 1.89VA CHAS MNT
166F6 数据手册
www.hammondmfg.com 166F6 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.06 / 52.3 B 1.38 / 35.1 C 1.19 / 30.2 Schematic Blk Hole to Hole Mounting Dims D Grn 1.75 / 44.5 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 1.89 Primary 115V 60 Hz. Secondary VAC 6.3 C.T. Secondary Amps 0.3 Primary / Grn/ Yel Blk Grn Secondary E
166F6 价格&库存
很抱歉,暂时无法提供与“166F6”相匹配的价格&库存,您可以联系我们找货
166F6
    • 1+256.050821+30.59645
    • 10+221.1549010+26.42661
    • 25+211.8489125+25.31460
    • 50+206.0611650+24.62300
    • 100+201.16606100+24.03807
    • 250+195.83823250+23.40143
    库存:1
