229C10
229C10
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 24VA THRU HOLE
229C10 数据手册
www.hammondmfg.com 229C10 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.25” (57 mm) B 2.87” (73 mm) C 1.25” (32 mm) D 0.60” (15 mm) D1 0.53” (13 mm) E 1.90” (48 mm) PC Board Spacing 1.50” (38 mm) Pin Size 0.04” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 24 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 10V C.T. @ 2.4A Secondary (RMS) Parallel 5V @ 4.8A Regulation 15% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229C10 价格&库存
很抱歉,暂时无法提供与“229C10”相匹配的价格&库存,您可以联系我们找货
229C10
  • 1+241.621011+31.26013
  • 10+215.3274610+27.85836
  • 25+205.6495625+26.60626
  • 50+198.6111850+25.69566
  • 100+191.80769100+24.81545
  • 250+183.16418250+23.69718
  • 500+176.88343500+22.88460
库存:8
