166G5
166G5
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 2.5VA CHAS MOUNT
166G5 数据手册
www.hammondmfg.com 166G5 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.06 / 52.3 B 1.38 / 35.1 C 1.19 / 30.2 Schematic Blk Hole to Hole Mounting Dims D Grn 1.75 / 44.5 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 2.5 Primary 115V 60 Hz. Secondary VAC 5 C.T. Secondary Amps 0.5 Primary / Grn/ Yel Blk Grn Secondary E
166G5 价格&库存
很抱歉,暂时无法提供与“166G5”相匹配的价格&库存,您可以联系我们找货
166G5
    • 1+260.442401+31.12122
    • 10+225.1447010+26.90337
    • 25+215.7363425+25.77913
    • 50+209.8856850+25.08001
    • 100+204.94043100+24.48908
    • 250+199.55556250+23.84563
    库存:4
