166G10
166G10
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 5VA CHAS MOUNT
166G10 数据手册
www.hammondmfg.com 166G10 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.38 / 60.5 B 1.5 / 38.1 C 1.38 / 35.1 Schematic Blk Hole to Hole Mounting Dims D Grn 2 / 50.8 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 5 Primary 115V 60 Hz. Secondary VAC 10 C.T. Secondary Amps 0.5 Primary / Grn/ Yel Blk Grn Secondary E
166G10 价格&库存
很抱歉,暂时无法提供与“166G10”相匹配的价格&库存,您可以联系我们找货
