166C50
166C50
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 3.75VA CHAS MNT
166C50 数据手册
www.hammondmfg.com 166C50 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.38 / 60.5 B 1.38 / 35.1 C 1.38 / 35.1 Schematic Blk Hole to Hole Mounting Dims D Grn 2 / 50.8 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 3.75 Primary 115V 60 Hz. Secondary VAC 50 C.T. Secondary Amps 0.075 Primary / Grn/ Yel Blk Grn Secondary E
166C50
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗的特点。
3. 引脚分配:EL817共有3个引脚,分别为Vcc、Out和GND。
4. 参数特性:工作电压范围为3-6V,工作电流为0.1mA,接收频率为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,用于控制各种电子设备。
6. 应用信息:广泛应用于电视、空调、音响等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP-8封装。
166C50 价格&库存
很抱歉,暂时无法提供与“166C50”相匹配的价格&库存,您可以联系我们找货
166C50
  • 1+235.538261+30.26996
  • 10+212.0698210+27.25393
  • 25+203.3010125+26.12702
  • 50+196.8764850+25.30138
  • 100+190.63594100+24.49938
  • 250+182.66060250+23.47444
  • 500+176.83018500+22.72515
库存:4
