166E25
166E25
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 3.75VA CHAS MNT
166E25 数据手册
www.hammondmfg.com 166E25 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.38 / 60.5 B 1.38 / 35.1 C 1.38 / 35.1 Schematic Blk Hole to Hole Mounting Dims D Grn 2 / 50.8 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 3.75 Primary 115V 60 Hz. Secondary VAC 25 C.T. Secondary Amps 0.15 Primary / Grn/ Yel Blk Grn Secondary E
166E25 价格&库存
很抱歉,暂时无法提供与“166E25”相匹配的价格&库存,您可以联系我们找货
166E25
    • 1+217.492141+25.98893
    • 10+185.9122310+22.21533
    • 25+177.4833025+21.20813
    • 50+172.2424850+20.58189
    • 100+167.80813100+20.05201
    • 250+162.98271250+19.47540
    • 500+159.98113500+19.11673
    库存:5
