166D25
166D25
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 2.5VA CHAS MOUNT
166D25 数据手册
www.hammondmfg.com 166D25 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.06 / 52.3 B 1.38 / 35.1 C 1.19 / 30.2 Schematic Blk Hole to Hole Mounting Dims D Grn 1.75 / 44.5 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 2.5 Primary 115V 60 Hz. Secondary VAC 25 C.T. Secondary Amps 0.1 Primary / Grn/ Yel Blk Grn Secondary E
166D25 价格&库存
很抱歉,暂时无法提供与“166D25”相匹配的价格&库存,您可以联系我们找货
166D25
  • 1+299.249491+37.48955
  • 10+269.3202710+33.74006
  • 25+258.1508525+32.34077
  • 50+249.9756350+31.31659
  • 100+242.03220100+30.32145
  • 250+231.88468250+29.05018
库存:4
