166N12B
166N12B
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 48VA CHAS MOUNT
166N12B 数据手册
www.hammondmfg.com 166N12B Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 3.69 / 93.7 B 2 / 50.8 C 2.31 / 58.7 Schematic Blk Hole to Hole Mounting Dims D Grn 3.13 / 79.5 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 48 Primary 117V 50/60 Hz. Secondary VAC 12 C.T. Secondary Amps 4 Primary / Grn/ Yel Blk Grn Secondary E
166N12B 价格&库存
很抱歉,暂时无法提供与“166N12B”相匹配的价格&库存,您可以联系我们找货
166N12B
  • 1+282.868911+36.75954
  • 10+252.0768310+32.75803
  • 25+240.7420125+31.28504
  • 50+232.4949450+30.21331
  • 100+224.52944100+29.17818
  • 250+214.40943250+27.86306
库存:31
