166F30
166F30
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 7.5VA CHAS MOUNT
166F30 数据手册
www.hammondmfg.com 166F30 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 2.81 / 71.4 B 1.5 / 38.1 C 1.69 / 42.9 Schematic Blk Hole to Hole Mounting Dims D Grn 2.38 / 60.5 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 7.5 Primary 115V 60 Hz. Secondary VAC 30 C.T. Secondary Amps 0.25 Primary / Grn/ Yel Blk Grn Secondary E
166F30 价格&库存
很抱歉,暂时无法提供与“166F30”相匹配的价格&库存,您可以联系我们找货
166F30
  • 1+245.442131+30.74864
  • 10+220.9298910+27.67778
  • 25+211.7880725+26.53251
  • 50+205.0946050+25.69396
  • 100+198.59381100+24.87955
  • 250+190.28294250+23.83838
  • 500+184.20846500+23.07738
库存:1
