229D10
229D10
    HAMMONDMANUFACTURING
    XFRMR SEMI-TORO 48VA THRU HOLE
229D10 数据手册
www.hammondmfg.com 229D10 Power Transformer - Dual Primary Low Voltage PC Board Mount - Low Profile Features • Low profile mounting, dual - split bobbin design. • Low primary to secondary coupling, balanced windings, no electrostatic shield required and low EMF radiation due to semi-toroidal design. Mechanical A 2.50” (64 mm) B 3.12” (79 mm) C 1.38” (35 mm) D 0.60” (15 mm) D1 0.66” (17 mm) E 2.18” (55 mm) PC Board Spacing 1.50” (38 mm) Pin Size 0.04” x 0.04” (1 mm x 1 mm) Electrical Size (VA) 48 Primary 115 /230V, 50 /60Hz Secondary (RMS) Series 10V C.T. @ 4.8A Secondary (RMS) Parallel 5V @ 9.6A Regulation 15% • Universal dual primary 115/230V - 50/60 Hz. • High insulation - Hipot of 1,750V RMS. • Class B insulation - 130 degrees C. • C UL US recognized.
229D10 价格&库存
很抱歉,暂时无法提供与“229D10”相匹配的价格&库存,您可以联系我们找货
229D10
  • 1+298.477421+38.61602
  • 10+265.9822310+34.41190
  • 25+254.0208725+32.86438
  • 50+245.3201550+31.73871
  • 100+236.91331100+30.65106
  • 250+226.23404250+29.26942
库存:15
