10/4/22, 6:01 AM
Low Voltage Chassis Mount - 25 VA to 175 VA (185 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Low Voltage Chassis Mount - 25 VA to 175 VA 185 Series
Global Use - 115/230 V Primary
Features
Dual primary 115/230 VAC
50/60 Hz. operation
Dual secondaries for series or parallel connections
4,000 V RMS Hipot test
Class F insulation (155 degrees, C)
Chassis mount (either two or four hole depending on size)
Five VA sizes to choose from
Dual bobbin construction
Dual use terminals (solder lug or quick connect)
C UL US recognized (E207860)
TUV Type Approved
CE certified to IEC 950 (Approved to EN 60-742 Safety Isolating Transformers)
A connection sheet can be downloaded here.
NOTE: Products produced after January 1st, 2021 will no longer have a TUV Label,
however we do carry plenty of TUV-labeled inventory. Please contact us for more
details.
Secondary
Overall Dimensions
VAC (RMS)
Includes Mounting Feet
Hole to Hole
Weight
Mounting Diameter
Terminal Lug Data
Mounting
Part No.
VA
Series
Parallel
Width
Depth
Height
(lbs)
Width
Depth
Width
Thickness
Figure
185C10
25
10V C.T. @2.5A
5V@5.0A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D10
43
10V C.T. @4.3A
5V@8.6A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E10
80
10V C.T. @8.0A
5V@16.0A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
https://www.hammfg.com/electronics/transformers/power/185
1/2
10/4/22, 6:01 AM
Secondary
Overall Dimensions
VAC (RMS)
Hole to Hole
Weight
Mounting Diameter
Terminal Lug Data
Mounting
Part No.
VA
Series
Parallel
Width
Depth
Height
(lbs)
Width
Depth
Width
Thickness
Figure
185F10
130
10V C.T. @13.0A
5V@26.0A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G10
175
10V C.T. @17.5A
5V@35.0A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C12
25
12.6V C.T. @2.0A
6.3V@4.0A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D12
43
12.6V C.T. @3.4A
6.3V@6.8A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E12
80
12.6V C.T. @6.3A
6.3V@12.6A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F12
130
12.6V C.T. @10.3A
6.3V@20.6A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G12
175
12.6V C.T. @14.0A
6.3V@28.0A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C16
25
16V C.T. @1.6A
8V@3.2A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D16
43
16V C.T. @2.7A
8V@5.4A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E16
80
16V C.T. @5.0A
8V@10.0A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F16
130
16V C.T. @8.1A
8V@16.2A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G16
175
16V C.T. @11.0A
8V@22.0A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C20
25
20V C.T. @1.25A
10V@2.5A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D20
43
20V C.T. @2.2A
10V@4.4A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E20
80
20V C.T. @4.0A
10V@8.0A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F20
130
20V C.T. @6.5A
10V@13.0A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G20
175
20V C.T. @8.8A
10V@17.6A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C24
25
24V C.T. @1.0A
12V@2.0A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D24
43
24V C.T. @1.8A
12V@3.6A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E24
80
24V C.T. @3.3A
12V@6.6A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F24
130
24V C.T. @5.4A
12V@10.8A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G24
175
24V C.T. @7.3A
12V@14.6A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C28
25
28V C..T @0.9A
14V@1.86A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D28
43
28V C.T. @1.5A
14V@3.0A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E28
80
28V C.T. @2.8A
14V@5.6A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F28
130
28V C.T. @4.6A
14V@9.2A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G28
175
28V C.T .@6.25A
14V@12.5A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C36
25
36V C.T. @0.7A
18V@1.4A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D36
43
36V C.T. @1.2A
18V@2.4A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E36
80
36V C.T. @2.2A
18V@4.4A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F36
130
36V C.T. @3.6A
18V@7.2A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G36
175
36V C.T. @4.8A
18V@9.6A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
185C230
25
230V C.T. @0.11A
115V@0.22A
2.81
2.22
2.31
1.25
2.37
0.19
0.02
A
185D230
43
230V C.T. @0.19A
115V@0.38A
3.12
2.22
2.68
1.75
2.81
0.19
0.02
A
185E230
80
230V C.T. @0.35A
115V@0.7A
2.50
2.61
3.00
2.50
2.00
2.18
0.19
0.02
B
185F230
130
230V C.T. @0.57A
115V@1.14A
2.81
3.07
3.37
4.00
2.25
2.50
0.25
0.03
B
185G230
175
230V C.T. @0.76A
115V@1.52A
3.12
3.20
3.75
5.00
2.50
2.50
0.25
0.03
B
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“185E36”相匹配的价格&库存,您可以联系我们找货
