166M24
166M24
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 72VA CHAS MOUNT
166M24 数据手册
www.hammondmfg.com 166M24 Power Transformer - Low Voltage/ Filament Economical Single Primary - Open Style Chassis Mount GRN C B A BLK D Features • Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table below) • Open style, channel bracket, chassis mount. • Minimum 6” long leads. • Dual bobbin design - no electrostatic shield required. • Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A (105 degree, C) design • Hi-Pot test of 2,000V RMS. • CSA certified. BLK GRN GRN/ YEL Overall Dimensions (in. / mm) A 4.03 / 102.4 B 2.25 / 57.2 C 2.63 / 66.8 Schematic Blk Hole to Hole Mounting Dims D Grn 3.56 / 90.4 Mounting Hole Sizes Width-wise 0.187 / 4.7 Depth-wise / Electrical Size (VA) 72 Primary 115V 60 Hz. Secondary VAC 24 C.T. Secondary Amps 3 Primary / Grn/ Yel Blk Grn Secondary E
166M24 价格&库存
很抱歉,暂时无法提供与“166M24”相匹配的价格&库存,您可以联系我们找货
166M24
  • 1+363.488541+45.46409
  • 10+327.0340110+40.90446
  • 25+313.4380725+39.20392
  • 50+303.4873650+37.95932
  • 100+293.82529100+36.75082
  • 250+281.48515250+35.20735
库存:3
