262B12
262B12
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 7VA CHAS MOUNT
262B12 数据手册
10/4/22, 2:50 AM Plate & Filament or Bias - 6 VA to 83 VA (261-262 Series) - Hammond Mfg. Quality Products. Service Excellence. Plate & Filament or Bias - 6 VA to 83 VA 261-262 Series 115 V Primary Features Primary 115 VAC, 60 Hz. (Except 261D6 & 261GE6 which are 115/230 50/60 Hz.) and (262EE5 which is 120/240, 50/60 Hz) Designed for small power or bias supplies, test equipment, preamps etc. Models 261C6, 261D6, 261E6, and 261G6 can also be used with full wave C.T. rectifiers. Economical , two hole, channel bracket, chassis mount. Minimum 5" long leads. Convenient 6.3 or 12.6 volt filament/auxiliary winding.     Part No. VA A.C. A.C. Filament Schematic Secondary #1 Secondary #2 Figure # RMS or PDF 261C6 17.5 250V C.T. @ 45 ma RMS 6.3V @ 1A 1 261D6 19.4 250V C.T. @ 50 ma 6.3V @ 1.1A See PDF Dimensions A B C D 3.25 1.65 2.00 2.81 - - - - Weight G (Lbs) 0.19 1 - 1.5 261E6 29 250V C.T. @ 91 ma 6.3V @ 1A 1 3.69 1.85 2.31 3.13 0.19 1.7 261G6 45 250V C.T. @ 130 ma 6.3V @ 2A 1 4.00 2.25 2.63 3.56 0.19 2 261GE6 45 250V C.T. @ 130 ma 6.3V @ 2A 1 4.00 2.25 2.63 3.56 0.19 2 4.50 2.50 2.93 4.00 0.20 x 0.31 261M6 83 215V @ 269 ma 6.3V @ 4A 2 262A12 6 125V @ 15ma 12.6V @ 0.3A See PDF 262B6 7 120V @ 43 ma 6.3V @ 0.3A 2 262B12 9 120V @ 45 ma 12.6V @ 0.3A 262B24 8 120V @ 27 ma 262D6 12 120V @ 53 ma 262D12 12 262E6 - - 2.81 1.50 1.68 2.38 0.19 0.6 2 2.81 1.50 1.68 2.38 0.19 0.6 12/12V @ 0.2/0.2A 3 2.81 1.50 1.68 2.38 0.19 0.6 6.3V @ 0.9A 2 3.25 1.62 2.00 2.81 0.19 1 120V @ 53 ma 12.6V @ 0.45A 2 3.25 1.62 2.00 2.81 0.19 1 18 120V @ 87 ma 6.3V @ 1.2A 2 3.25 2.00 2.00 2.81 0.19 1.3 262EE6 18 120V @ 93 ma 6.3V @ 1.2 A See PDF - 1..3 262E12 18 120V @ 87 ma 12.6V @ 0.6A 2 3.25 2.00 2.00 2.81 0.19 1.3 262F6 26 120V @ 140 ma 6.3V @ 1.5A 2 3.69 1.85 2.31 3.13 0.19 1.7 262F12 26 120V @ 140 ma 12.6V @ 0.75A 2 3.69 1.85 2.31 3.13 0.19 1.5 - - - - 4 - - - - Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/classic/261-262 1/2 10/4/22, 2:50 AM Plate & Filament or Bias - 6 VA to 83 VA (261-262 Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/classic/261-262 2/2
262B12 价格&库存
很抱歉,暂时无法提供与“262B12”相匹配的价格&库存,您可以联系我们找货
262B12
  • 1+317.884701+39.86336
  • 10+286.0685510+35.87355
  • 25+274.1891325+34.38385
  • 50+265.4998450+33.29419
  • 100+257.05627100+32.23535
  • 250+246.27400250+30.88324
库存:1
