10/3/22, 1:35 AM
Low Voltage, Filament - 15 VA to 640 VA (167 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Low Voltage, Filament - 15 VA to 640 VA 167 Series
Enclosed, Chassis Mount - 115 V Primary
Features
Primary 115 VAC, 60 Hz.
All secondaries center tapped, VAC (RMS)
Enclosed, 4 hole chassis mount.
Minimum 6" long leads.
Dual bobbin design - no electrostatic shield required.
Class B insulation (130 degrees C).
Hi-Pot test of 2,000V RMS.
UL listed (# E50394) & CSA certified (209651).
Secondary (R.M.S.)
Dimensions
Mounting Slot
Part No.
VA
VAC
Amps
A
B
C
D
E
167M5
15
5 C.T.
3
1.88
2.19
2.50
1.50
1.31
0.19
x
0.31
167Q5
30
5 C.T.
6
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167R5
40
5 C.T.
8
2.19
2.50
2.63
1.75
1.44
0.19
x
0.25
167U5
75
5 C.T.
15
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167X5
150
5 C.T.
30
3.13
3.50
3.81
2.50
2.19
0.20
x
0.38
167N6
25.2
6.3 C.T.
4
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167Q6
37.8
6.3 C.T.
6
2.19
2.38
2.63
1.75
1.31
0.19
x
0.25
https://www.hammfg.com/electronics/transformers/power/167
G
1/3
10/3/22, 1:35 AM
Secondary (R.M.S.)
Part No.
VA
VAC
167R6
50.4
167S6
63
167T6
Dimensions
Mounting Slot
Amps
A
B
C
D
E
G
6.3 C.T.
8
2.19
2.63
2.63
1.75
1.56
0.19
x
0.25
6.3 C.T.
10
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
75.6
6.3 C.T.
12
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167U6
100.8
6.3 C.T.
16
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167U7
112.5
7.5 C.T.
15
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167V7
157.5
7.5 C.T.
21
3.13
3.50
3.81
2.50
2.19
0.20
x
0.38
167R10
80
10 C.T.
8
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167S10
100
10 C.T.
10
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167L12
31.5
12.6 C.T.
2.5
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167N12
50.4
12.6 C.T.
4
2.19
2.63
2.63
1.75
1.56
0.19
x
0.25
167Q12
75.6
12.6 C.T.
6
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167R12
100.8
12.6 C.T.
8
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167S12
126
12.6 C.T.
10
2.50
3.75
3.06
2.00
2.69
0.20
x
0.38
167V12
252
12.6 C.T.
4.00
4.56
3.00
2.81
0.20
x
0.38
167M16
48
16 C.T.
3
2.19
2.63
2.63
1.75
1.56
0.19
x
0.25
167P16
80
16 C.T.
5
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167M18
54
18 C.T.
3
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167P18
90
18 C.T.
5
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167M20
60
20 C.T.
3
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167P20
100
20 C.T.
5
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167U20
320
20 C.T.
16
3.75
4.50
4.56
3.00
3.31
0.20
x
0.38
167T22
264
22 C.T.
12
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167V22
440
22 C.T.
5.00
4.56
3.00
3.81
0.20
x
0.38
167L24
48
24 C.T.
2
2.19
2.63
2.63
1.75
1.56
0.19
x
0.25
167J25
25
25 C.T.
1
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167K25
37.5
25 C.T.
1.5
2.19
2.38
2.63
1.75
1.31
0.19
x
0.25
167M25
75
25 C.T.
3
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167N25
100
25 C.T.
4
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167P25
125
25 C.T.
5
2.50
3.75
3.06
2.00
2.69
0.20
x
0.38
167S25
250
25 C.T.
10
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167J28
28
28 C.T.
1
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167L28
56
28 C.T.
2
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167M28
84
28 C.T.
3
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167K30
45
30 C.T.
1.5
2.19
2.50
2.63
1.75
1.44
0.19
x
0.25
167S30
300
30 C.T.
10
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167J33
33
33 C.T.
1
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167J36
36
36 C.T.
1
2.19
2.38
2.63
1.75
1.31
0.19
x
0.25
167L36
72
36 C.T.
2
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167M36
108
36 C.T.
3
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167P36
180
36 C.T.
5
3.13
3.75
3.81
2.50
2.44
0.20
x
0.38
167R36
288
36 C.T.
8
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167T36
432
36 C.T.
12
3.75
5.00
4.56
3.00
3.81
0.20
x
0.38
167L44
88
44 C.T.
2
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167L50
100
50 C.T.
2
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167P50
250
50 C.T.
5
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167G55
27.5
55 C.T.
0.5
1.88
2.44
2.50
1.50
1.56
0.19
x
0.31
167J55
55
55 C.T.
1
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167L55
110
55 C.T.
2
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167J60
60
60 C.T.
1
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167L60
120
60 C.T.
2
2.50
3.75
3.06
2.00
2.69
0.20
x
0.38
167M60
180
60 C.T.
3
3.13
3.75
3.81
2.50
2.44
0.20
x
0.38
167S64
640
64 C.T.
10
3.75
5.50
4.56
3.00
4.31
0.20
x
0.38
167L70
140
70 C.T.
2
2.50
3.75
3.06
2.00
2.69
0.20
x
0.38
167N70
280
70 C.T.
4
3.75
4.00
4.56
3.00
2.81
0.20
x
0.38
167G80
40
80 C.T.
0.5
2.19
2.50
2.63
1.75
1.44
0.19
x
0.25
2/3
10/3/22, 1:35 AM
Secondary (R.M.S.)
Part No.
Dimensions
Mounting Slot
VA
VAC
Amps
A
B
C
D
E
G
167J80
80
80 C.T.
1
2.50
3.00
3.06
2.00
1.94
0.20
x
0.38
167L80
160
80 C.T.
2
3.13
3.50
3.81
2.50
2.19
0.20
x
0.38
167N80
320
80 C.T.
4
3.75
4.50
4.56
3.00
3.31
0.20
x
0.38
167G100
50
100 C.T.
0.5
2.19
2.63
2.63
1.75
1.56
0.19
x
0.25
167J100
100
100 C.T.
1
2.50
3.25
3.06
2.00
2.19
0.20
x
0.38
167P100
500
100 C.T.
5
3.75
5.50
4.56
3.00
4.31
0.20
x
0.38
167G120
60
120 C.T.
0.5
2.50
2.75
3.06
2.00
1.69
0.20
x
0.38
167H200
174
200 C.T.
0.87
3.13
3.75
3.81
2.50
2.44
0.20
x
0.38
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
3/3
很抱歉,暂时无法提供与“167J50”相匹配的价格&库存,您可以联系我们找货
