185G10
185G10
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 175VA CHAS MOUNT
185G10 数据手册
10/4/22, 6:01 AM Low Voltage Chassis Mount - 25 VA to 175 VA (185 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage Chassis Mount - 25 VA to 175 VA 185 Series Global Use - 115/230 V Primary Features Dual primary 115/230 VAC 50/60 Hz. operation Dual secondaries for series or parallel connections 4,000 V RMS Hipot test Class F insulation (155 degrees, C) Chassis mount (either two or four hole depending on size) Five VA sizes to choose from Dual bobbin construction Dual use terminals (solder lug or quick connect) C UL US recognized (E207860) TUV Type Approved CE certified to IEC 950 (Approved to EN 60-742 Safety Isolating Transformers) A connection sheet can be downloaded here.     NOTE:  Products produced after January 1st, 2021 will no longer have a TUV Label, however we do carry plenty of TUV-labeled inventory.  Please contact us for more details. Secondary Overall Dimensions VAC (RMS) Includes Mounting Feet Hole to Hole Weight Mounting Diameter Terminal Lug Data Mounting Part No. VA Series Parallel Width Depth Height (lbs) Width Depth Width Thickness Figure 185C10 25 10V C.T. @2.5A 5V@5.0A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D10 43 10V C.T. @4.3A 5V@8.6A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E10 80 10V C.T. @8.0A 5V@16.0A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B https://www.hammfg.com/electronics/transformers/power/185 1/2 10/4/22, 6:01 AM Low Voltage Chassis Mount - 25 VA to 175 VA (185 Series) - Hammond Mfg. Secondary Overall Dimensions VAC (RMS) Includes Mounting Feet Hole to Hole Weight Mounting Diameter Terminal Lug Data Mounting Part No. VA Series Parallel Width Depth Height (lbs) Width Depth Width Thickness Figure 185F10 130 10V C.T. @13.0A 5V@26.0A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G10 175 10V C.T. @17.5A 5V@35.0A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C12 25 12.6V C.T. @2.0A 6.3V@4.0A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D12 43 12.6V C.T. @3.4A 6.3V@6.8A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E12 80 12.6V C.T. @6.3A 6.3V@12.6A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F12 130 12.6V C.T. @10.3A 6.3V@20.6A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G12 175 12.6V C.T. @14.0A 6.3V@28.0A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C16 25 16V C.T. @1.6A 8V@3.2A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D16 43 16V C.T. @2.7A 8V@5.4A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E16 80 16V C.T. @5.0A 8V@10.0A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F16 130 16V C.T. @8.1A 8V@16.2A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G16 175 16V C.T. @11.0A 8V@22.0A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C20 25 20V C.T. @1.25A 10V@2.5A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D20 43 20V C.T. @2.2A 10V@4.4A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E20 80 20V C.T. @4.0A 10V@8.0A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F20 130 20V C.T. @6.5A 10V@13.0A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G20 175 20V C.T. @8.8A 10V@17.6A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C24 25 24V C.T. @1.0A 12V@2.0A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D24 43 24V C.T. @1.8A 12V@3.6A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E24 80 24V C.T. @3.3A 12V@6.6A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F24 130 24V C.T. @5.4A 12V@10.8A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G24 175 24V C.T. @7.3A 12V@14.6A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C28 25 28V C..T @0.9A 14V@1.86A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D28 43 28V C.T. @1.5A 14V@3.0A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E28 80 28V C.T. @2.8A 14V@5.6A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F28 130 28V C.T. @4.6A 14V@9.2A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G28 175 28V C.T .@6.25A 14V@12.5A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C36 25 36V C.T. @0.7A 18V@1.4A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D36 43 36V C.T. @1.2A 18V@2.4A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E36 80 36V C.T. @2.2A 18V@4.4A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F36 130 36V C.T. @3.6A 18V@7.2A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G36 175 36V C.T. @4.8A 18V@9.6A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B 185C230 25 230V C.T. @0.11A 115V@0.22A 2.81 2.22 2.31 1.25 2.37 - 0.19 0.02 A 185D230 43 230V C.T. @0.19A 115V@0.38A 3.12 2.22 2.68 1.75 2.81 - 0.19 0.02 A 185E230 80 230V C.T. @0.35A 115V@0.7A 2.50 2.61 3.00 2.50 2.00 2.18 0.19 0.02 B 185F230 130 230V C.T. @0.57A 115V@1.14A 2.81 3.07 3.37 4.00 2.25 2.50 0.25 0.03 B 185G230 175 230V C.T. @0.76A 115V@1.52A 3.12 3.20 3.75 5.00 2.50 2.50 0.25 0.03 B Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/185 2/2
185G10 价格&库存
很抱歉,暂时无法提供与“185G10”相匹配的价格&库存,您可以联系我们找货
