SPECIFICATIONS
(RoHS Compliant)
Model Number:
Part Number:
JQ48B7
19031328A
Rev:01
Jun 29, 2022
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 48 vdc
= 24 - 56 vdc
= 0.42 amps
= 1.00 amps
= 20.1 watts
= 3500 rpm
= Ball
= 235 CFM
= 54.3 dBA
Construction:
Venturi: Die-Cast Aluminum, Black
Propeller: Plastic, Black, UL 94V-0
Life Expectancy:
This fan is designed for continuous duty life of 75,000
hours at 40C.
Agency Approvals:
UL, CUL, CE
Brushless DC Motor
Polarity Protected
Locked Rotor Protection
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
-10C to 70C
-40C to 85C
Tachometer:
Output:
Ic:
Pulses Per Rev:
Isolated:
5 VDC TTL Compatible
5 mA Typical
2
No
Termination:
12” Lead wires, AWG 22, UL 1061
Red
= Power (+)
Black
= Return (-)
Blue/White
= Tachometer (Output)
PQ Curve:
很抱歉,暂时无法提供与“19031328A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+803.763651+100.51668
- 20+727.1914720+90.94076
- 40+631.5082440+78.97485
- 60+593.2352960+74.18853
- 100+516.68930100+64.61588
