SPECIFICATIONS
(RoHS Compliant)
Model Number:
Part Number:
MD24B5
19028886A Drawing Number: 26021750A00
Jan.01.2013
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 24 vdc
= 12 - 28 vdc
= 0.250 amps
= 0.750 amps
= 6.0 watts
= 3100 rpm
= Ball
= 110 CFM
= 50.0 dBA
Construction:
Venturi: Die-Cast Zinc Alloy, Black
Propeller: Plastic, Black, UL 94V-0
Life Expectancy:
This fan is designed for continuous duty life of 83,000
hours at 40C.
Agency Approved:
UL, CE
Brushless DC Motor
Electronic Locked Rotor Protected
Polarity Protected
Automatic Restart Capability
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Tachometer Output:
Isolated:
Output:
Ic:
Pulse per Revolution:
No
5 V TTL Compatible
5 mA Typical
1
Termination:
12” Lead wires, 22 AWG, UL 1061
Red - Fan Power (+)
Black - Fan Ground (-)
Blue/White – Tachometer (Output)
很抱歉,暂时无法提供与“19028886A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+330.258971+41.30137
- 20+307.1967720+38.41727
- 40+276.4775540+34.57560
- 60+270.4202960+33.81809
