182G240
182G240
    HAMMONDMANUFACTURING
    XFRMR TOROIDAL 120VA CHAS MOUNT
182G240 数据手册
10/5/22, 6:33 AM Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA (182 Series) - Hammond Mfg. Quality Products. Service Excellence. Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA 182 Series Note: This product line will soon be discontinued as a stocked series. Available while quantities last. It has been replaced with 1182 Series. For alternative solution assistance, please contact Hammond here or call: USA (716) 630-7030, Canada and International (519) 822-2960. Features Low profile, lightweight, cool running - due to high efficiency toroidal design Dual 117/234 VAC primary, 50/60 Hz. operation Units are designed to have all windings engaged. Center single hole mounting - units over 225VA include a potted center (see photos below) for extra mounting strength. Supplied with two rubber insulating pads, one metal centering washer and all mounting hardware (160VA and under) Supplied with one bottom rubber insulating pad and mounting hardware (225VA and larger) Center bolt size varies with VA - see tables below. Minimum 8" long flexible leads Hi-Pot test of 4,000V RMS between primary & secondary CSA certified to C22.2 #66 - CSA file #209651   UL recognized to UL506 - UL file #E207860 CE certified to IEC950 Note about Inrush Current:  Due to the superior magnetic properties of Toroidal transformers they will be susceptible to high magnetizing current when initially energized, only limited by the low DC resistance of the primary winding. Depending on where you are in the AC cycle when the transformer is energized dictates the chances of overloading the supply circuit. This is why the transformer may sometimes energize without a problem and other times it will blow the fuse or trip the circuit breaker. The duration of this overload is rarely longer than a half of a cycle. Therefore, you should consider using a slow-blow fuse, time delayed circuit breaker or other form of soft start circuitry for the supply line when using these high efficient Toroidal transformers. https://www.hammfg.com/electronics/transformers/power/182 1/4 10/5/22, 6:33 AM Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA (182 Series) - Hammond Mfg. Included Mounting Top Steel Mounting Washer VAC Secondary (RMS) Dual or Single Toroid Outside Potted with Top & Bottom Weight Length Rubber Washer (lbs.) 8-32 1.50 Yes 0.76 10-24 2.00 Yes 1.12 10-24 2.00 Yes 1.67 10-24 2.00 Yes 2.15 No 8-32 1.50 Yes 0.76 No 10-24 2.00 Yes 1.12 1.73 No 10-24 2.00 Yes 1.67 3.73 1.52 No 10-24 2.00 Yes 2.15 Open 3.98 1.68 No 10-24 2.00 Yes 2.84 Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 12V @ 4.16A Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 24V C.T. @ 3.33A 12V @ 6.66A Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 120 24V C.T. @ 5A 12V @ 10A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182Q12 160 24V C.T. @ 6.67A 12V @ 13.34A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182S12 225 24V C.T. @ 9.38A 12V @ 18.76A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182T12 300 24V C.T. @ 12.5A 12V @ 25A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182G15 15 30V C.T. @ .5A 15V @ 1A Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182J15 30 30V C.T. @ 1A 15V @ 2A Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 182K15 50 30V C.T. @ 1.67A 15V @ 3.34A Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182M15 80 30V C.T. @ 2.67A 15V @ 5.34A Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182N15 120 30V C.T. @ 4A 15V @ 8A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182P15 160 30V C.T. @ 5.33A 15V @ 10.66A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182H15 225 30V C.T. @ 7.5A 15V @ 15A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182S15 300 30V C.T. @ 10A 15V @ 20A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182F18 15 36V C.T. @ .42A 18V @ .84A Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182H18 30 36V C.T. @ .83A 18V @ 1.66A Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 Part No. VA Series Parallel Secondary 182K6 15 12V C.T. @ 1.25A 6V @ 2.5A Dual Open 2.70 1.25 No 182L6 30 12V C.T. @ 2.5A 6V @ 5A Dual Open 2.95 1.60 No 182N6 50 12V C.T. @ 4.17A 6V @ 8.34A Dual Open 3.63 1.73 No 182Q6 80 12V C.T. @ 6.67A 6V @ 13.34A Dual Open 3.73 1.52 No 182H9 15 18V C.T. @ .83A 9V @ 1.66A Dual Open 2.70 1.25 182K9 30 18V C.T. @ 1.67A 9V @ 3.34A Dual Open 2.95 1.60 182M9 50 18V C.T. @ 2.78A 9V @ 5.56A Dual Open 3.63 182N9 80 18V C.T. @ 4.44A 9V @ 8.88A Dual Open 182Q9 120 18V C.T. @ 6.67A 9V @ 13.34A Dual 182G12 15 24V C.T. @ .63A 12V @ 1.26A 182K12 30 24V C.T. @ 1.25A 12V @ 2.5A 182L12 50 24V C.T. @ 2.08A 182M12 80 182P12 Hardware Size Center Diameter Height Center Thread 182J18 50 36V C.T. @ 1.39A 18V @ 2.78A Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182L18 80 36V C.T. @ 2.22A 18V @ 4.44A Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182M18 120 36V C.T. @ 3.33A 18V @ 6.66A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182N18 160 36V C.T. @ 4.44A 18V @ 8.88A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182G18 225 36V C.T. @ 6.25A 18V @ 12.5A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182F22 15 44V C.T. @ .34A 22V @ .68A Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182G22 30 44V C.T. @ .68A 22V @ 1.36A Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 182J22 50 44V C.T. @ 1.14A 22V @ 2.28A Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182L22 80 44V C.T. @ 1.82A 22V @ 3.64A Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182M22 120 44V C.T. @ 2.73A 22V @ 5.46A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182N22 160 44V C.T. @ 3.64A 22V @ 7.28A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182P22 225 44V C.T. @ 5.11A 22V @ 10.22A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182S24 500 48V C.T. @ 10.42A 24V @ 20.82A Dual Potted 5.50 2.21 Yes 1/4-20 2.50 Bottom Rubber Washer Only 8.46 182T24 625 48V C.T. @ 13.02A 24V @ 26.04A Dual Potted 6.10 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 10.38 182U24 750 48V C.T. @ 15.63A 24V @ 31.26A Dual Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182V24 1000 48V C.T. @ 20.8A 24V @ 41.7A Dual Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182K30 80 60V C.T. @ 1.33A 30V @ 2.66A Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182L30 120 60V C.T. @ 2A 30V @ 4A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182M30 160 60V C.T. @ 2.67A 30V @ 5.34A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182F30 225 60V C.T. @ 3.75A 30V @ 7.5A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182P30 300 60V C.T. @ 5A 30V @ 10A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182R30 500 60V C.T. @ 8.33A 30V @ 16.66A Dual Potted 5.50 2.21 Yes 1/4-20 2.50 Bottom Rubber Washer Only 8.46 182S30 625 60V C.T. @ 10.42A 30V @ 20.84A Dual Potted 6.10 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 10.38 182T30 750 30V @ 25A Dual Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182U30 1000 60V C.T. @ 16.7A 30V @ 33.3A Dual Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182V40 1500 80V C.T. @ 18.8A 40V @ 37.5A Dual Potted 7.20 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 24.97 60V @ 5A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182L60 300 60V C.T. @ 12.5A 120V C.T. @ 2.5A https://www.hammfg.com/electronics/transformers/power/182 2/4 10/5/22, 6:33 AM Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA (182 Series) - Hammond Mfg. Included Mounting Top Steel Mounting Washer VAC Secondary (RMS) Part No. VA Series 182N60 500 120V C.T. @ 4.17A 182P60 182Q60 Dual or Single Toroid Outside Potted Parallel Secondary 60V @ 8.34A Dual Potted 5.50 2.21 Yes 625 120V C.T. @ 5.21A 60V @ 10.42A Dual Potted 6.10 3.10 Yes Hardware Size with Top & Bottom Weight Length Rubber Washer (lbs.) 1/4-20 2.50 Bottom Rubber Washer Only 8.46 3/8-16 3.50 Bottom Rubber Washer Only 10.38 Center Diameter Height Center Thread 750 120V C.T. @ 6.25A 60V @ 12.5A Dual Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182R60 1000 120V C.T. @ 8.3A 60V @ 16.7A Dual Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182T60 1500 120V C.T. @ 12.5A 60V @ 25A Dual Potted 7.20 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 24.97 182D110 15 220V C.T. @ 68ma 110V @ 136ma Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182E110 30 220V C.T. @ 136ma 110V @ 272ma Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 182G110 50 220V C.T. @ 227ma 110V @ 454ma Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182H110 80 220V C.T. @ 364ma 110V @ 728ma Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182J110 120 220V C.T. @ 545ma 110V @ 1.09A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182K110 160 220V C.T. @ 727ma 110V @ 1.45A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182L110 225 220V C.T. @ 1.02A 110V @ 2.04A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182M110 300 220V C.T. @ 1.36A 110V @ 2.72A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182P110 500 220V C.T. @ 2.27A 110V @ 4.54A Dual Potted 5.50 2.21 Yes 1/4-20 2.50 Bottom Rubber Washer Only 8.46 182Q110 625 220V C.T. @ 2.84A 110V @ 5.68A Dual Potted 6.10 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 10.38 182R110 750 220V C.T. @ 3.41A 110V @ 6.82A Dual Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182S110 1000 220V C.T. @ 4.5A 110V @ 9.1A Dual Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182U110 1500 220V C.T. @ 6.8A 110V @ 13.6A Dual Potted 7.20 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 24.97 182D117 15 234V C.T. @ 64ma 117V @ 128ma Dual Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182E117 30 234V C.T. @ 128ma 117V @ 256ma Dual Open 2.95 1.60 No 10-24 2.00 Yes 1.12 182G117 50 234V C.T. @ 214ma 117V @ 428ma Dual Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182H117 80 234V C.T. @ 342ma 117V @ 684ma Dual Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182J117 120 234V C.T. @ 513ma 117V @ 1.02A Dual Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182K117 160 234V C.T. @ 684ma 117V @ 1.37A Dual Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182L117 225 117V @ 1.92A Dual Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182M117 300 234V C.T. @ 1.28A 117V @ 2.56A Dual Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182N117 500 234V C.T. @ 2.14A 117V @ 4.28A Dual Potted 5.50 2.21 Yes 1/4-20 2.50 Bottom Rubber Washer Only 8.46 182P117 625 234V C.T. @ 2.67A 117V @ 5.34A Dual Potted 6.10 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 10.38 182Q117 750 234V C.T. @ 3.21A 117V @ 6.42A Dual Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182R117 1000 234V C.T. @ 4.3A 117V @ 8.5A Dual Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182T117 1500 234V C.T. @ 6.4A 117V @ 12.8A Dual Potted 7.20 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 24.97 182B240 15 - 240V @ 63ma Single Open 2.70 1.25 No 8-32 1.50 Yes 0.76 182D240 30 - 240V @ 125ma Single Open 2.95 1.60 No 10-24 2.00 Yes 1.12 182E240 50 - 240V @ 208ma Single Open 3.63 1.73 No 10-24 2.00 Yes 1.67 182F240 80 - 240V @ 333ma Single Open 3.73 1.52 No 10-24 2.00 Yes 2.15 182G240 120 - 240V @ .5A Single Open 3.98 1.68 No 10-24 2.00 Yes 2.84 182H240 160 - 240V @ 667ma Single Open 4.43 1.73 No 1/4-20 2.50 Yes 3.87 182J240 225 - 240V @ .94A Single Potted 4.97 1.90 Yes 1/4-20 2.50 Bottom Rubber Washer Only 4.96 182K240 300 - 240V @ 1.25A Single Potted 5.06 2.27 Yes 1/4-20 2.50 Bottom Rubber Washer Only 5.58 182L240 500 - 240V @ 2.08A Single Potted 5.50 2.21 Yes 1/4-20 2.50 Bottom Rubber Washer Only 8.46 182M240 625 - 240V @ 2.6A Single Potted 6.10 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 10.38 182N240 750 - 240V @ 3.13A Single Potted 6.40 3.10 Yes 3/8-16 3.50 Bottom Rubber Washer Only 13.53 182P240 1000 - 240V @ 4.17A Single Potted 6.50 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 16.49 182Q240 1500 - 240V @ 6.3A Single Potted 7.20 3.50 Yes 3/8-16 3.50 Bottom Rubber Washer Only 24.97 234V C.T. @ .96A Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/182 3/4 10/5/22, 6:33 AM Toroidal L.V. - Chassis Mount - 15 VA to 1500 VA (182 Series) - Hammond Mfg. https://www.hammfg.com/electronics/transformers/power/182 4/4
182G240
物料型号:182系列 器件简介:这是一系列环形低压底盘安装变压器,容量从15VA到1500VA。注意,这个产品系列将很快停产,现有库存售完即止。已被1182系列替代。 引脚分配:文档中提到了多种变压器的引脚分配,例如182K6型号的变压器有12V中心抽头(C.T.)@1.25A和6V@2.5A的输出,具体引脚分配根据型号有所不同。 参数特性:变压器具有低剖面、轻量级、高效率的环形设计,双117/234VAC初级,50/60Hz操作。所有绕组均参与工作。中心单孔安装,超过225VA的单元包括灌封中心以增强安装强度。 功能详解:变压器在初次通电时可能会因为高磁化电流而容易受到冲击,这取决于通电时在交流周期中的位置。建议使用慢熔保险丝、延时断路器或其他形式的软启动电路。 应用信息:适用于需要高效率和低剖面变压器的应用场合。 封装信息:提供了不同容量变压器的尺寸、高度、中心孔直径、安装硬件尺寸等详细信息。
182G240 价格&库存
很抱歉,暂时无法提供与“182G240”相匹配的价格&库存,您可以联系我们找货
