19039992A
19039992A
    COMAIRROTRON
    插件
    19039992A
19039992A 数据手册
SPECIFICATIONS Model Number: Part Number : GL24S3TDN-E2 039992 January 31, 2006 Mechanical Drawing: Additional Features: Motor: (Max Speed) Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 12 - 28 vdc = 0.630 amps = 1.350 amps = 15.0 Watts = 3200 RPM = Ball = 150 CFM = 53.6 dBA Construction: Venturi: Die Cast Zinc, Black Propeller: Plastic, Black, UL 94V-0 Brushless DC Motor Locked Rotor Protection Automatic Restart Capability Polarity Protected Operating Temperature: -10°C to 70°C Storage Temperature: -40°C to 85°C Enviro-Shield Type 2 Coating Thermal Speed Control - PTC on Hub Fan Performance Sensor: Output: Ic Vcc 5 volt TTL 20mA Max. 28vdc High on Pass, Low on Fail 10 sec. ± 4 sec. No No This fan is designed for continuous duty life of 82,500 hours at 50°C. Logic: Delay: Latching: Isolated: Agency Certifications: Termination: UL, CSA, TUV 12” Lead wires, 22 AWG, UL 1061 Red – Power (+) Black – Ground (-) Blue/White – FPS Life Expectancy:
19039992A 价格&库存
很抱歉,暂时无法提供与“19039992A”相匹配的价格&库存,您可以联系我们找货
