SPECIFICATIONS
(RoHS Compliant)
Model Number:
Part Number:
JQD24C3E6
16005460A
Version: 00
Apr 18, 2017
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow at Full Speed
Acoustics at Full Speed
Additional Features:
= 24 vdc
= 16 - 32 vdc
= 0.60 amps
= 1.00 amps
= 14.4 watts
= 3000 rpm
= Ball
= 200 cfm
= 50.8dBA
Construction:
Venturi:
Propeller:
Die-cast aluminum, Black
Plastic, Black, UL 94V-0
Brushless DC Motor
Polarity Protected
Locked Rotor Protection
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
-10°C to 70°C
-40°C to 85°C
Tachometer:
Output:
I c:
Vce:
Pulse per Revolution:
Isolated:
Open Collector
20mA Max
32vdc Max
2
No
Agency Approvals:
Speed Control:
UL, CE
PWM: 100 ~ 20 KHz, 2.8 ~ 20 V TTL
95% Duty or Open Lead Wire: Full Speed
Life Expectancy:
This fan is designed for continuous duty life of 75,000
hours at 40°C
Termination:
12" Lead wires, AWG 22, UL 1061
Red - Power (+)
Black - Return (-)
Blue/White - Tachometer (Output)
Yellow – Program (Input)
很抱歉,暂时无法提供与“16005460A”相匹配的价格&库存,您可以联系我们找货
