19030769A
19030769A
    COMAIRROTRON
    插件
    19030769A
19030769A 数据手册
SPECIFICATIONS Model Number: Part Number: SD48B5 19030769A December 16, 2004 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Airflow Acoustic = 48 vdc = 24 – 56 vdc = 0.065 amps = 0.250 amps = 3.1 watts = 3500 RPM = Ball = 35 CFM = 47.6 dBA Construction: Venturi: Single Piece Die-Cast Zinc Alloy, Black Propeller: Plastic, Black, UL 94V-0 Agency Approvals: UL, CE Life Expectancy: This fan is designed for continuous duty life of 83,000 hours at 40C. Additional Features: Brushless DC Motor Automatic Restart Capability Locked Rotor Protection Polarity Protected Operating Temperature: Storage Temperature: -10C to 70C -40C to 85C Tachometer: Output: 5 Vdc TTL Compatible Ic: 5 mA Typical Isolated: No Pulses per Revolution: 1 Termination: 12” Length, AWG 22, UL 1061 Red = Power (+) Black = Return (-) Blue/White = Tachometer (Output)
19030769A
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有较高的电流传输比(CTR)和较快的响应速度。 3. 引脚分配:EL817有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、C(集电极)、E(发射极)、G(栅极)和KC(集电极)。 4. 参数特性:主要参数包括Vceo(集电极-发射极击穿电压)为80V,Ic(集电极电流)为50mA,Ctr(电流传输比)为100%,Ton(导通时间)为1.5us,Toff(关断时间)为100us。 5. 功能详解:EL817通过输入端的LED发光,光信号触发输出端的晶体管导通,实现电信号的隔离传输。 6. 应用信息:EL817适用于多种应用场景,如开关电源、测量设备、通信设备等需要信号隔离的场合。 7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
19030769A 价格&库存
很抱歉,暂时无法提供与“19030769A”相匹配的价格&库存,您可以联系我们找货
