SPECIFICATIONS
Model Number:
Part Number:
SD24K5
19031706A
December 16, 2003
Mechanical Drawing:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 24 vdc
= 12 – 28 vdc
= 0.320 amps
= 1.60 amps
= 7.70 watts
= 4900
= Ball
= 50 CFM
= 55.4 dBA
Construction:
Venturi: Single Piece Die-Cast Zinc Alloy, Black
Propeller: Plastic, Black, UL 94V-0
Agency Approvals:
UL,CE
Life Expectancy:
This fan is designed for continuous duty life of 83,000
hours at 40C.
Brushless DC Motor
Locked Rotor Protection
Polarity protected
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
-10C to 70C
-40C to 85C
Tachometer:
Isolated:
Output:
Ic:
Pulses per Revolution:
No
5 Vdc TTL Compatible
10 mA Typical
1
Termination:
12” Lead wires, AWG 22, UL 1061
Red
= Power (+)
Black
= Return (-)
Blue/White
= Tachometer Output
很抱歉,暂时无法提供与“19031706A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+393.641941+48.83110
- 20+303.8709020+37.69505
- 40+286.1387640+35.49538
- 60+284.4946060+35.29143
