19032364A
19032364A
    COMAIRROTRON
19032364A 数据手册
SPECIFICATIONS Model Number: Part Number: SPD24B1QDN 19032364A SPEC Number: 26014020A November.23.2011 Mechanical Drawing: Features: Specifications: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 12 - 28 vdc = 1.250 amps = 2.000 amps = 30.0 watts = 2500 rpm = Ball = 60 CFM = 57.0 dBA Construction: Polarity Protected Brushless DC Motor Design Electronic Locked Rotor Protection Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Fan Performance Sensor: Output: Ic Vcc Backplate: Die-Cast Zinc Alloy Housing & Propeller: Plastic, Black, UL 94V-0 Logic: Delay: Latching: Life Expectancy: Termination: This fan is designed for continuous duty life of 62,000 hours at 50C. Agency Approvals: UL Open Collector 20mA mzx 28 vdc max High on pass/Low on fail 10 sec +/- 4 No 12” Lead wires, 22 AWG, UL 1061 Fan power - Red Fan ground - Black FPS power - Red/White FPS ground - Black/White FPS signal - Blue/White
19032364A
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚集电极,4脚发射极,5脚GND,6脚Vcc。
4. 参数特性:工作温度范围为-20℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有抗干扰能力强、响应速度快等特点。
6. 应用信息:广泛应用于工业控制、仪器仪表、医疗设备等领域。
7. 封装信息:采用DIP6封装方式。
19032364A 价格&库存
很抱歉,暂时无法提供与“19032364A”相匹配的价格&库存,您可以联系我们找货
