SPECIFICATIONS
Model Number:
Part Number:
ST12K7
19031530A
May 16, 2002
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Max. Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Noise Level
= 12 vdc
= 6 - 14 vdc
= 0.380 amps
= 1.250 amps
= 4.6 watts
= 4200 RPM
= Ball
= 40.0 CFM
= 44.2 dB(A)
Construction:
Venturi: Plastic, Black, UL 94V-0
Propeller: Plastic, Black, UL 94V-0
Agency Approvals:
UL, CE
Life Expectancy:
This fan is designed for continuous duty life of 78,000
hours at 40C.
Brushless DC Motor
Locked Rotor Protection
Polarity Protected
Automatic Restart Capability
Operating Temperature:
Storage Temperature:
-10C to 70C
-40C to 85C
Tachometer
Output:
5V TTL compatible
Ic:
5 mA Typical
Pulses per Revolution: 2
Isolated:
No
Termination:
12” Lead wires, 22 AWG, UL 1061
Red
= Power (+)
Black
= Return (-)
Blue/White
= Tachometer (Output)
很抱歉,暂时无法提供与“19031530A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 300+356.79139300+46.05472
