19044018A
19044018A
    COMAIRROTRON
    插件
    19044018A
19044018A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: SPEC Number: MFXE48Z3D3-E2 19044018A 26017474A Rev:00 Apr 03, 2013 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Max. Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 48 vdc = 24 - 72vdc = 1.55 amps = 3.00 amps = 74.4 watts = 5400 rpm = Ball = 400 CFM = 69 dBA Construction: Venturi: Propeller: Die Cast Aluminum Alloy, Black. Plastic, Black, UL 94V-0. Agency Approvals: UL, CE Life Expectancy: This fan is designed for continuous duty life of 75,000 hours at 40°C. Brushless DC Motor Locked Rotor Protection Reverse Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -20°C to 70°C -40°C to 85°C Alarm Output (FPS): Open Collector (NPN Transistor) High on Pass, Low on Fail Vcc: 60Vdc Max Sink Current (Ic): 20mA Max Isolated: No Latching: No Delay: 10±4s Termination: 12” length lead wires, 20AWG, UL 1007 Black – Return(-) Blue – FPS Red – Power(+) Comair Rotron Specification Sheet Specification Date: Apr 03, 2013 48V Mixed Flow P-Q Curve
19044018A 价格&库存
很抱歉,暂时无法提供与“19044018A”相匹配的价格&库存,您可以联系我们找货
