19030714A
19030714A
    COMAIRROTRON
    插件
    19030714A
19030714A 数据手册
SPECIFICATIONS RoHS Compliant Model Number: Part Number: WD48B7 030714 December 16, 2004 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 48vdc = 24 - 56vdc = 0.090 amps = 0.235 amps = 4.3 watts = 2475 rpm = Ball = 85 CFM = 41.1 dBA Construction: Venturi: Die-Cast Zinc Alloy, Black Propeller: Plastic, Black, UL 94V-0 Agency Approvals: UL Life Expectancy: This fan is designed for continuous duty life of 83,000 hours at 40°C. Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10°C to 70°C -40°C to 85°C Tachometer: Output: 5 Vdc TTL Compatible Ic: 5 mA Typical Isolated: No Pulses per Revolution: 1 Termination: 12” Length, AWG 22, UL 1061 Red = Power (+) Black = Return (-) Blue/White = Tachometer (Output)
19030714A 价格&库存
很抱歉,暂时无法提供与“19030714A”相匹配的价格&库存,您可以联系我们找货
