SPECIFICATIONS
Model Number:
Part Number:
TNE2A
19020174A
(RoHS Compliant)
Version: 01
Jan 09, 2018
Mechanical Drawing:
Motor:
Nominal Voltage
Frequency
Nominal Running Current
Max. Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
Additional Features:
= 115 VAC
= 50 / 60 Hz
= 0.45 / 0.49 Amps
= 1.25 / 1.35 Amps
= 48 / 59 Watts
= 2820 / 3350 RPM
= Ball
= 280 / 340 CFM
= 61.6 / 65.4 dBA
Construction:
Venturi: Plastic, Black, UL 94V-0
Propeller & Cover: Plastic, Black, UL 94V-0
Life Expectancy:
This fan is designed for continuous duty life of
45,000 hours at 60C.
Permanent Split Capacitor
Automatic Reset Thermal Protector
Thermal Shutdown Protection
Class B Insulation
Operating Temperature:
-10C to 70C
Storage Temperature:
-40C to 85C
Termination:
2x0.12” Terminals
Agency Approvals:
UL, CUL, CE
PQ Curve:
很抱歉,暂时无法提供与“19020174A”相匹配的价格&库存,您可以联系我们找货
