19039693A
19039693A
    COMAIRROTRON
    插件
    19039693A
19039693A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: JQD48Z3A2 19039693A Version: 02 Apr 19, 2017 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Static Pressure Acoustic Additional Features: = 48 vdc = 24 - 72 vdc = .720 amps = 1.250 amps = 35 watts = 4450 rpm = Ball = 300 CFM = 1.30” of Water = 60.2 dBA Brushless DC Motor Soft Start Inrush Current Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -40°C to 85°C Storage Temperature: -40°C to 85°C Programmable: PWM Input, 5 volt TTL 0% Duty: 100% Duty: Off 4450 RPM Construction: Tachometer Specifications: Venturi: Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0 Output: Agency Approvals: UL, CE, UL 507 5 volt TTL compatible Ic: 5 mA. Typ. Pulses per Revolution: 2 Isolated: No Termination: Life Expectancy: 12” Lead wires, 22 AWG, UL 1061 This fan is designed for continuous duty life of 50,000 hours at 40°C. Red - Power (+) Black - Return (-) Blue/White - Tachometer Yellow - Program Lead 2” Programmable harness, Connector, Molex 050579005 Pin Contact, Moelx 16020069 PQ Curve:
19039693A 价格&库存
很抱歉,暂时无法提供与“19039693A”相匹配的价格&库存,您可以联系我们找货
