19028885A
19028885A
    COMAIRROTRON
    插件
    19028885A
19028885A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: Drawing Number: MD12B5 19028885A 26021749A00 January 25 2013 Mechanical Drawing: Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow(see curve attached) = 12 vdc = 6 - 14vdc = 0.500 amps = 1.500 amps = 6.0 watts = 3100 rpm = Ball = 110 CFM Construction: Venturi: Die-Cast Zinc Alloy, Black Propeller: Polypropylene, Black, UL94V-0 Brushless DC Motor Electronic Locked Rotor Protected Polarity Protected Automatic Restart Capability Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Tachometer: Output: Ic: Isolated: Pulses per Rev.: 5 volt TTL 5 mA Max. No 1 Termination: Life Expectancy: This fan is designed for continuous duty life of 83,000 hours at 40C. 12” Lead wires, 22AWG, UL 1061 Red - Fan Power, (+) Black - Fan Ground, (-) Blue/White – Tachometer, (output)
19028885A 价格&库存
很抱歉,暂时无法提供与“19028885A”相匹配的价格&库存,您可以联系我们找货
