17000659A
17000659A
    COMAIRROTRON
    17000659A
17000659A 数据手册
Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 COMAIR ROTRON PART NUMBER: COMAIR ROTRON MODEL NUMBER: 17000659A CREC2258-4000E1B A.) MOTOR: RATED VOLTAGE: 115 VAC START VOLTAGE: 87 VAC OPERATING VOLTAGE RANGE: 103~126 VAC OPERATING FREGUENCY: 50/60 Hz MAX. RUNNING CURRENT: 1.4 Amps INPUT POWER: 109 Watts NOMINAL SPEED: 4000 RPM 10% (At Free Delivery) MOTOR TYPE: Brushless EC MOTOR PROTECTION: By Integrated Circuit LOCKED ROTORT PROTECTION: IC protected POLARITY PROTECTION: Yes AUTOMATIC RESTART CAPABILITY: By Integrated Circuit ROTATION: Counterclockwise when viewed from the impeller B.) MECHANICAL DIMENSIONS: 225x225x80 mm Figure 1 WEIGHT: 1.83 Kg BEARING TYPE: Permanently Lubricated Ball Bearings VENTURI: High quality magnesium alloy die-casting frame with ED coating& powder coating. PROPELLER: High quality magnesium alloy die-casting frame with ED coating& powder coating. -1- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 Figure 1 C.) ENVIRONMENTAL OPERATING TEMPERATURE: -20C to +70C STORAGE TEMPERATURE: The storage temperature will be suggested at -20℃ ~ 50℃ to ensure a better performance. HUMIDITY: 20 to 85% RH, non-condensing D.) PERFORMANCE CHARACTERISTICS 838 CFM  5%, Curve D (At Free Delivery and MAX. speed) AIR FLOW: -2- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 1.58” Inches of H20, Curve D STATIC PRESSURE: (At Shut-Off and MAX. speed) ACOUSTIC LEVEL: 74 dBA Max. at MAX. speed (Measured via Freely Suspended at 1 meter ) -3- Comair Rotron Specification Sheet Specification Date: Feb 27, 2018 RoHS Compliant Version: 01 E.) TERMINATION Suit with terminal block, PV1.25-3A-0.5 terminal F.) RELIABILITY Bearing type Ball bearing Temperature 20℃ Hours 60,000 40℃ 50,000 60℃ 40,000 90℃ 20,000 G.) SAFETY UL, CUL, TUV, CE -4-
17000659A
1. 物料型号: 17000659A CREC2258-4000E1B 2. 器件简介: - 额定电压: 115 VAC - 启动电压: 87 VAC - 工作电压范围: 103~126 VAC - 工作频率: 50/60 Hz - 最大运行电流: 1.4 安培 - 输入功率: 109 瓦特 - 额定转速: 4000 RPM ±10%(无负载时) - 电机类型: 无刷 EC 电机 - 电机保护: 集成电路保护 - 锁定转子保护: IC 保护 - 极性保护: 是 - 自动重启能力: 集成电路控制 - 旋转方向: 从叶轮处看为逆时针方向 3. 引脚分配: 适合使用 PV1.25-3A-0.5 端子的端子块 4. 参数特性: - 尺寸: 225x225x80 mm - 重量: 1.83 公斤 - 轴承类型: 永久润滑球轴承 - 通风口: 高质量镁合金压铸框架,带有电镀和粉末涂层 - 叶轮: 高质量镁合金压铸框架,带有电镀和粉末涂层 5. 功能详解: - 气流: 838 CFM ± 5%(无负载和最大速度时) - 静压: 1.58 英寸水柱(关闭和最大速度时) - 噪音水平: 最大 74 dBA(在 1 米处通过自由悬挂测量) 6. 应用信息: 未在文档中明确说明 7. 封装信息: 环境工作温度: -20°C 至 +70°C;存储温度建议在 -20°C 至 50°C 以确保更好的性能;湿度: 20 至 85% RH,非凝结 8. 可靠性: 球轴承在不同温度下的寿命 9. 安全: 符合 UL, CUL, TUV, CE 安全标准
17000659A 价格&库存
很抱歉,暂时无法提供与“17000659A”相匹配的价格&库存,您可以联系我们找货
