16003387A
16003387A
    COMAIRROTRON
    16003387A
16003387A 数据手册
SPECIFICATIONS Model Number: WT24Z7-E2 Part Number: 16003387A Feb. 16, 2013 Mechanical Drawing: Motor: Additional Features: Nominal Voltage = 24 vdc Operating Voltage Range = 12 to 28 vdc Nominal Running Current = 0.42 Amps Max. Locked Rotor Current = 1.50 Amps Running Power = 10.2 Watts Average Speed = 5300 RPM Bearings = Ball Air Flow = 20 CFM Acoustic = 56.8 dBA Brushless DC Motor Locked Rotor Protection Automatic Restart Capability Polarity Protected Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Enviroshield Type 2 Construction: Venturi: Plastic, Black, UL 94V-0 Propeller: Polypropylene, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 25C. Agency Approvals: UL, CE Tachometer: Output: 5v TTL Compatible Ic: 5mA Typical Pulses per Revolution: 2 Isolated: No Termination: 12” leadwires, 22AWG, UL 1061 Red - Power (+) Black - Return (-) Blue/white - Tach
16003387A 价格&库存
很抱歉,暂时无法提供与“16003387A”相匹配的价格&库存,您可以联系我们找货
