SPECIFICATIONS
RoHS Compliant
Model Number:
Part Number:
PQ12B4QNN
039355
SPEC Number:26013423A
Nov.2.2011
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustic
= 12 Vdc
= 9 – 14 Vdc
= 2.22 Amps
= 3.50 Amps
= 26.3 Watts
= 3500 RPM
= Ball
= 235 CFM
= 51.2 dBA
Construction:
Venturi: Single piece, die-cast aluminum, painted black
Propeller: Polycarbonate, painted black
Life Expectancy:
This fan is designed for continuous duty life of 75,000
hours at 40C
Agencies:
UL,CE
Polarity Protected
Locked Rotor Protection
Automatic Restart Capability
Operating Temperature Range: -10C to +70C
Storage Temperature Range:
-40C to +85C
Fan Performance Sensor:
Output:
Ic:
Vce:
Logic:
Isolated:
Delay:
Latching:
Open Collector
20 mA Max.
28 Vdc Max.
High on Pass, Low on Fail
Yes
No
No
Termination:
Fan Power – 2 Blade Terminals
Alarm - 12” Lead Wires, 22 AWG, UL1061
Alarm Power – Red/White
Alarm Signal – Blue/White
Alarm Return – Black/White
很抱歉,暂时无法提供与“19039355A”相匹配的价格&库存,您可以联系我们找货
