SPECIFICATIONS
Model Number:
Part Number:
MT48B6NDNX
031927
March 11, 1999
Mechanical Drawing:
Additional Features:
Motor:
Nominal Voltage
Operating Voltage Range
Nominal Running Current
Max. Locked Rotor Current
Running Power
Average Speed
Bearings
Air Flow
Acoustics
= 48 Volts DC
= 24 to 56 Volts DC
= 0.72 Amps
= 1.300 Amps
= 35 Watts
= 3400 RPM
= Ball
= 300 CFM
= 57.1 dBA
Construction:
Venturi: Single piece diecast aluminum, black.
Propeller: Polycarbonate, UL94V-0 rated, black.
Brushless DC
Electronic Locked Rotor Protected
Polarity Protection
Operating Temperature: -10 deg C to +70 deg C
Storage Temperature:
-40 deg C to +85 deg C
Fan Performance Sensor (FPS):
Output:
Inverted Open Collector
Ic:
80mA Max.
Vc:
60VDC Max.
Logic Level:
Low on Pass, High on Fail
Delay:
10+/-4 seconds
Latching:
No
Isolated:
No
Trip Point:
1900 RPM
Life Expectancy:
This fan is designed for continuous duty life of 76,000 hours
at 40C
Agency Certification:
UL, CSA, TUV
Termination:
24” Harness Assembly, 22AWG, UL Style 1061
Molex Plug - 03-06-2032
Red = (+) Fan Power
Black = (-) Fan Ground
Blue/White = FPS Output
很抱歉,暂时无法提供与“19031927A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+596.59705100+77.42741
