19039671A
19039671A
    COMAIRROTRON
    插件
    19039671A
19039671A 数据手册
SPECIFICATIONS (Rohs Compliant) Model Number: JQ24K7 Part Number: 19039671A SPEC NUMBER:26013939A01 Feb 17, 2013 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic = 24 vdc = 12 - 28 vdc = 1.60 amps = 3.00 amps = 39.0 watts = 4200 RPM = Ball = 283 CFM = 58.3 dBA Construction: Venturi: Die-cast aluminum, Black Propeller: Plastic, Black, UL 94V-0 Agency Certifications: UL Life Expectancy: This fan is designed for continuous duty life of 70,000 hours at 40C. Brushless DC Motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: Storage Temperature: -10C to 70C -40C to 85C Tachometer: Output: 5 Vdc TTL compatible Ic: 5 mA Typ. Isolated: No Pulses per Revolution: 2 Termination: 12” Lead wires, AWG 22, UL 1061 Red - Power Black - Ground Blue/White - Tachometer
19039671A
- 物料型号:JQ24K7 - 器件简介:COMAIR ROTRON 风扇,符合RoHS标准。 - 引脚分配: - 红色 - 电源 - 黑色 - 地 - 蓝/白 - 转速计输出 - 参数特性: - 电机类型:无刷直流电机 - 额定电压:24VDC - 工作电压范围:12 - 28VDC - 额定运行电流:1.60安培 - 堵转电流:3.00安培 - 运行功率:39.0瓦特 - 运行转速:4200转/分钟 - 轴承类型:球轴承 - 气流:283 CFM - 噪音:58.3 dBA - 功能详解: - 具有堵转保护、极性保护和自动重启功能。 - 应用信息: - 工作温度:-10°C 至 70°C - 存储温度:-40°C 至 85°C - 封装信息: - 外壳材料:压铸铝,黑色 - 螺旋桨:塑料,黑色,符合UL 94V-0标准 - 接线:12英寸长的线,AWG 22,符合UL 1061标准
19039671A 价格&库存
很抱歉,暂时无法提供与“19039671A”相匹配的价格&库存,您可以联系我们找货
