19041170A
19041170A
    COMAIRROTRON
    19041170A
19041170A 数据手册
SPECIFICATIONS Model Number: MC24B7X-E2 Part Number: 19041170A November 23, 2011 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Max Air Flow Acoustic = 24 vdc = 12 - 28 vdc = 0.23 amps = 0.83 amps = 5.5 watts = 3700 = Ball = 102 CFM = 47.8 dBA Construction: Venturi: Lexan 500, Black, UL94V-0 Propeller: Polypropylene, Black, UL94V-0 Additional Features: Brushless DC Motor Polarity Protected. Locked Rotor Protection. Automatic Restart 6-32 inserts on 8 mounting holes Enviroshield Type 2 Termination: 12” Lead Wires, 22 AWG, UL1061 Red – Power Black – Return Blue/White - Tachometer Tachometer Output: Life Expectancy: Output: This fan is designed for continuous duty life of 75,000 hours at 40C Ic: Pulse per Revolution: Isolated: Agency Approvals: UL 5 volt TTL Compatible 5mA Typical 2 No
19041170A
- 物料型号:MC24B7X-E2,部件编号:19041170A - 器件简介:COMAIR ROTRON 风扇,设计用于连续工作寿命75,000小时,工作温度40°C。 - 引脚分配:12英寸导线,22 AWG,UL1061标准。红色线 - 电源,黑色线 - 返回,蓝白色线 - 转速表。 - 参数特性:额定电压24VDC,工作电压范围12-28VDC,额定运行电流0.23安培,锁定转子电流0.83安培,运行功率5.5瓦特,平均速度3700转/分钟,最大风量102立方英尺/分钟,噪音等级47.8分贝。 - 功能详解:无刷直流电机,极性保护,锁定转子保护,自动重启,6-32插入件在8个安装孔上,Enviroshield Type 2。 - 应用信息:适用于需要高风量和低噪音的应用。 - 封装信息:Venturi部分采用Lexan 500黑色材料,UL94V-0认证;螺旋桨采用聚丙烯黑色材料,UL94V-0认证。
19041170A 价格&库存
很抱歉,暂时无法提供与“19041170A”相匹配的价格&库存,您可以联系我们找货
